首页 > 产品认证
[UL认证] UL 1651的认证申请
P:2007-07-25 17:41:53
Wire & Cable Construction Information Sheet: | ||||
UL File Number: | Date: | |||
Applicant Name & Address: | Contact Person: Tel. No.: Fax No.: | |||
UL Certification Required: (Please check) UL Listing Only (USL) UL and CUL Listing (USL / CNL) Reference standards: USL: UL 1651 CNL: CSA C22.2 No.232 | ||||
Type Designation: (Please check) Others _______________________ Temperature Rating (for CNL Listing): ______________________ (Ex: 60, 75, 90, 105, 125 or | ||||
General Construction: ________________________________________ (Ex:. flat laminate, parallel cord, single conductor, multiple conductor cable with jacket, jacketed coax, etc.) | ||||
Total No. of Fibers in Cable | No. of Fibers under Buffer | No. of Subunits | No. of Buffered Fibers per Subunit | |
Detailed Cable Construction:
Construction | Generic Material | Sizes or thickness | Material Source | Material Grade Designation |
Optical Fiber | | | ||
Coating | ||||
Buffer | Minimum Average Wall thickness = | |||
Strength Member in Subunit | ||||
Subunit Jacket | ||||
Central Strength Member | Rod: Coating: | Rod OD = Maximum Coating thickness = | ||
Strength Member under Overall Jacket | ||||
Ripcord | ||||
Outer Jacket | Minimum Average Wall thickness = |
IMPORTANT! - Attach Diagram showing each cable construction, dimensions, and materials.
addendum - 附录 (0) 投诉
