首页 > 电磁 漆包 音频
[音频线] BELDEN 1800B 库存
P:2014-05-16 11:12:22
<div class="ProductDetails cbs clearfix" style="position: relative; background-color: rgb(255, 255, 255); font-family: 'Segoe UI', Arial, Helvetica, sans-serif; font-size: 13px; line-height: 18px; ">
</div></div><div id="cphBody_pnlItemGroup" class="ItemGroupWrapper" style="zoom: 1; overflow: visible; position: relative; margin: 2em 0px 0px; font-family: 'Segoe UI', Arial, Helvetica, sans-serif; font-size: 13px; line-height: 18px; background-color: rgb(255, 255, 255); "><div class="ItemGroupDescription" style="position: relative; z-index: 2; ">
</div></div>
60-1800B
BELDEN 1800B CABLE VioletViolet
<div class="ProductDetailsL" style="position: absolute; ">Belden 1800B
</div><div class="ProductImages" style="clear: both; text-align: center; margin: 0px 55px; ">
</div></div><div id="cphBody_pnlItemGroup" class="ItemGroupWrapper" style="zoom: 1; overflow: visible; position: relative; margin: 2em 0px 0px; font-family: 'Segoe UI', Arial, Helvetica, sans-serif; font-size: 13px; line-height: 18px; background-color: rgb(255, 255, 255); "><div class="ItemGroupDescription" style="position: relative; z-index: 2; ">BELDEN 1800B - DIGITAL AUDIO FOIL SCREENED STRANDED CONDUCTOR TWIN CABLE
Foil screened cable for AES/EBU digital audio, with Beldfoil® (the foil bonded to the jacket) for easy stripping.
Technical Specification:
| Conductors: | 7/0.20mm (7/32AWG) (0.22mm sq.) (24AWG) tinned copper |
| Insulation: | Datalene® (foamed high density polyethylene), 1.72mm OD, red, black |
| Construction: | Two cores twisted together with 7/0.2mm tinned copper drain wire |
| Screen: | Beldfoil® (bonded to jacket) |
| Jacket: | PVC, 4.49mm OD, violet (grey available to special order) |
| Impedance: | 110 ohms |
| Capacitance: | 39pF/m core to core, 85pF/m core to core+screen |
| Weight: | 2.72kg/100m |
| Reel length: | 305m |
| Cut lengths: | Available in any multiple of 1 metre. |
OLUHO - Okinawa-Luzon-Hongkong Cable冲绳-吕宋-香港电缆 (0) 投诉
