首页 > 标准共享
[国外标准] DIN VDE 0282一套!
P:2014-04-09 11:17:00
DIN VDE 0282一套!有爱自下!
DIN VDE 0282-808-1994 Rubber insulated cables, wires and flexible cords for power installation.pdf
DIN VDE 0282-1-2003 Cables of rated voltages up to and including 450/750 V and having cross-linked insulation – Part 1: General requirements.pdf
DIN VDE 0282-2-2003 Cables of rated voltages up to and including 450/750 V and having cross-linked insulation – Part 2: Test methods.pdf
DIN VDE 0282-3-2000 Rubber insulated cables of rated voltages up to and including 450/750V – Part 3: Heat resistant silicone rubber insulated cables;.pdf
DIN VDE 0282-4-2003 Cables of rated voltages up to and including 450/750V and having cross-linked insulation–Part 4: Cords and flexible cables.pdf
DIN VDE 0282-8-2000 Rubber insulated cables of rated voltages up to and including 450/750 V – Part 8: Polychloroprene or equivalent synthetic elastomer sheathed cable for decorative chains.pdf
DIN VDE 0282-4 2005 额定电压450/750V及以下交联绝缘电缆 第4部分:线芯和软电缆 中文.pdf
DIN VDE 0282-6-2000 Rubber insulated cables of rated voltages up to and including 450/750 V – Part 6: Arc welding cables.pdf
DIN VDE 0282-7-2000 Rubber insulated cables of rated voltages up to and including 450/750 V – Part 7: Cables with increased heat resistance for internal wiring for a conductor temperature of 110 °C.pdf
DIN VDE 0282-13-2000 Rubber insulated cables of rated voltages up to and including 450/750V Part 13: Single and multicore flexible cables, insulated and sheathed with crosslinked polymer and having low emission of smoke and corrosive gases.pdf
DIN VDE 0282-9-2000 Rubber insulated cables of rated voltages up to and including 450/750 V – Part 9: Single core non-sheathed cables for fixed wiring having low emission of smoke and corrosive gases.pdf
DIN VDE 0282-10-2000 Rubber insulated cables of rated voltages up to and including 450/750V – Part 10: EPR insulated and polyurethane sheathed flexible cables.pdf
DIN VDE 0282-11-2000 Rubber insulated cables of rated voltages up to and including 450/750 V – Part 11: EVA cords and flexible cables.pdf
DIN VDE 0282-12-2000 Rubber insulated cables of rated voltages up to and including 450/750V – Part 12: Heat resistant EPR cords and flexible cables.pdf
DIN VDE 0282-807-1994 Rubber insulated cables, wires and flexible cords for power installation.pdf
DIN VDE 0282-14-2003 Cables of rated voltages up to and including 450/750 V and having cross-linked insulation – Part 14: Cords for applications requiring high flexibility.pdf
DIN VDE 0282-15-2000 Rubber insulated cables of rated voltage up to and including 450/750 V – Part 15: Multicore cables insulated and sheathed with heat resistant silicone rubbe.pdf
DIN VDE 0282-16-2000 Rubber insulated cables of rated voltages up to and including 450/750 V – Part 16: Water resistant polychloroprene or equivalent synthetic elastomer sheathed cables.pdf
tuned feeder - 谐振馈线,调谐馈线 (0) 投诉
