首页 > 新产品 新技术
[绿色环保] 屏蔽六类低烟无卤双绞线
P:2007-07-19 11:05:51
<DIV class=STYLE28 align=center> </DIV>
产品编号/型号: 屏蔽六类低烟无卤双绞线
<DIV class=style26 align=center>电气性能参数 </DIV>
用途: <DIV align=center>频率 </DIV><DIV align=center>回波损耗</DIV><DIV align=center>衰减 </DIV><DIV align=center>近端串扰</DIV><DIV align=center>近端串扰功率和</DIV>
100 Base-T4<DIV align=center>(MHz) </DIV><DIV align=center>(dB) </DIV><DIV align=center>(dB/100m) </DIV><DIV align=center></DIV><DIV align=center></DIV>
100 Base-TX<DIV align=center></DIV><DIV align=center>min. </DIV><DIV align=center>max </DIV><DIV align=center>min (dB) </DIV><DIV class=style26 align=center><DIV align=center>(dB)</DIV></DIV>
100VG - AnyLAN<DIV align=center>1.000 </DIV><DIV align=center>20.00</DIV><DIV align=center>2.00 </DIV><DIV align=center>74.30</DIV><DIV align=center>72.30</DIV>
1000 Base-T (Gigabit Ethernet)<DIV align=center>4.000 </DIV><DIV align=center>23.00 </DIV><DIV align=center>3.80</DIV><DIV align=center>65.30</DIV><DIV align=center>63.30 </DIV>
155 Mbps ATM <DIV align=center>8.000 </DIV><DIV align=center>24.50 </DIV><DIV align=center>5.30</DIV><DIV align=center>60.80</DIV><DIV align=center>58.80 </DIV>
622 Mbps AT<DIV align=center>10.00 </DIV><DIV align=center>25.00 </DIV><DIV align=center>6.00</DIV><DIV align=center>59.30</DIV><DIV align=center>57.30 </DIV>
参考标准<DIV align=center>16.00 </DIV><DIV align=center>25.00 </DIV><DIV align=center>7.60</DIV><DIV align=center>56.20</DIV><DIV align=center>54.20</DIV>
EIA/TIA 568B & ISO/IEC 11801 <DIV align=center>20.00 </DIV><DIV align=center>25.00 </DIV><DIV align=center>8.50</DIV><DIV align=center>54.80</DIV><DIV align=center>52.80</DIV>
<DIV class=STYLE27 align=center><DIV align=left>电缆结构 </DIV></DIV><DIV align=center>25.00 </DIV><DIV align=center>24.30 </DIV><DIV align=center>9.50</DIV><DIV align=center>53.30</DIV><DIV align=center>51.30</DIV>
导体材料实芯裸铜<DIV align=center>31.25 </DIV><DIV align=center>23.60 </DIV><DIV align=center>10.70</DIV><DIV align=center>51.90</DIV><DIV align=center>49.90</DIV>
AWG 23<DIV align=center>62.50 </DIV><DIV align=center>21.50</DIV><DIV align=center>15.40</DIV><DIV align=center>47.40</DIV><DIV align=center>45.40</DIV>
导体直径(mm)0.574<DIV align=center>100.00 </DIV><DIV align=center>20.10</DIV><DIV align=center>19.80</DIV><DIV align=center>44.30</DIV><DIV align=center>42.30</DIV>
绝缘材料实芯聚乙烯<DIV align=center>200.00</DIV><DIV align=center>18.00</DIV><DIV align=center>29.00</DIV><DIV align=center>39.80</DIV><DIV align=center>37.80</DIV>
<DIV align=center>250.00</DIV><DIV align=center>17.30</DIV><DIV align=center>32.80</DIV><DIV align=center>38.30</DIV><DIV align=center>36.30</DIV>
绝缘厚度 (mm) 0.2<DIV align=center>频率 </DIV><DIV align=center>远端串扰 </DIV><DIV align=center>等效远端串扰功率和 </DIV><DIV class=STYLE27 align=right><DIV align=center>衰减串扰比</DIV></DIV>
绝缘直径(mm) 0.95 <DIV align=center>(MHz) </DIV><DIV align=center>min (dB) </DIV><DIV align=center>min (dB) </DIV><DIV align=center></DIV><DIV align=center>(dB) </DIV>
排流线镀锡铜<DIV align=center>1.000 </DIV><DIV align=center>67.80</DIV><DIV align=center>64.80</DIV><DIV align=center></DIV><DIV align=center>72.30</DIV>
结构 (mm) 7/0.2<DIV align=center>4.000 </DIV><DIV align=center>55.80</DIV><DIV align=center>52.80</DIV><DIV align=center></DIV><DIV align=center>61.50</DIV>
屏蔽材料铝箔/铜丝编织<DIV align=center>8.000 </DIV><DIV align=center>49.70</DIV><DIV align=center>46.70</DIV><DIV align=center></DIV><DIV align=center>55.50</DIV>
  <DIV align=center>10.00 </DIV><DIV align=center>47.80</DIV><DIV align=center>44.80</DIV><DIV align=center></DIV><DIV align=center>53.30</DIV>
  <DIV align=center>16.00 </DIV><DIV align=center>43.70</DIV><DIV align=center>40.70</DIV><DIV align=center></DIV><DIV align=center>48.60</DIV>
护套材料低烟无卤<DIV align=center>20.00 </DIV><DIV align=center>41.80</DIV><DIV align=center>38.80</DIV><DIV align=center></DIV><DIV align=center>46.30</DIV>
护套厚度(mm) 1.1<DIV align=center>25.00 </DIV><DIV align=center>39.80</DIV><DIV align=center>36.80</DIV><DIV align=center></DIV><DIV align=center>43.80</DIV>
最大外径(mm) 6.1<DIV align=center>31.25 </DIV><DIV align=center>37.90</DIV><DIV align=center>34.90</DIV><DIV align=center></DIV><DIV align=center>41.20</DIV>
外护套可选材料聚氯乙烯/低烟低卤/低烟无卤<DIV align=center>62.50 </DIV><DIV align=center>31.90</DIV><DIV align=center>28.90</DIV><DIV align=center></DIV><DIV align=center>32.00</DIV>
护套颜色 按用户要求 <DIV align=center>100.00 </DIV><DIV align=center>27.80</DIV><DIV align=center>24.80</DIV><DIV align=center></DIV><DIV align=center>24.50</DIV>
弯曲半径6倍电缆最大外径<DIV align=center>200.00</DIV><DIV align=center>21.80</DIV><DIV align=center>18.80</DIV><DIV align=center></DIV><DIV align=center>10.80</DIV>
  <DIV align=center>250.00</DIV><DIV align=center>19.80</DIV><DIV align=center>16.80</DIV><DIV align=center></DIV><DIV align=center>5.50</DIV>
防火标准导体最大直流电阻20℃(Ω/Km) <93.8
火焰传播测试通过 IEC 60332标准第一部分(LSOH)
火焰传播测试通过 IEC 60332 标准第一三部分(LSFROH)
卤素酸气指数达到 IEC60754 第一部分的标准
烟密度测试达到 IEC61034 标准
工作温度 ℃70
传播率74%
特性阻抗(ohm) 100±15
unattended repeating station - 无人增音站 (0) 投诉
P:2007-07-19 11:22:11
好多其他的文字,乱。有没有原文件的压缩包下载呀?
electric wire - 电线,导线 (0) 投诉
P:2007-07-19 12:37:29
FTP cat.6, 铜丝0.574 绝缘实芯结构外径做0.95  你的阻抗能测过,还有你的弯曲半径是6倍!这些数据看起来都有点不可思议,在忽悠人的吧!
control of paper tension - 纸带张力控制 (0) 投诉
P:2007-07-19 15:08:19
乱,晕!
leaky mode - 漏泄模 (0) 投诉
P:2007-07-31 10:17:47
thank you very much
crown - 隆起,隆起部;凸度;轧辊凸面 (0) 投诉
P:2009-08-03 19:34:04
FTP cat.6, 铜丝0.574 绝缘实芯结构外径做0.95,结构不合理
RT - room temperature室温 (0) 投诉
P:2009-09-12 23:18:57
UTP6类的就要0.60。。。。
metal-shielded wire - 金属屏蔽线 (0) 投诉
