首页 > 国外线缆
[问题求助] 1631电子线的有关知识
P:2007-07-17 14:03:28
有哪位大侠知道一些有关1631电子线方面的东东啊?如使用的原材料,技术标准,生产流程,检测方法等等的,谢谢了!
[limingxing 在 2007-10-9 14:37:55 编辑过]
ring specimen - 环状试片 (0) 投诉
P:2007-07-20 13:29:12
怎么又没的人理哦!!!
thermal rating - 耐温等级 (0) 投诉
P:2007-07-20 19:38:25
可以自己查阅UL758活页以及UL1581。
underground distribution chamber - 地下配线室,电缆地下室 (0) 投诉
P:2007-08-06 13:51:56
UNDERWRITERS LABORATORIES INC.             APPLIANCE WIRING MATERIAL
Subj. 758      Section 1     Page 1631       Issued:  1981-05-20
                                     Revised:  2003-02-26
Style 1631    Polyethylene Insulated - Coaxial Cable.
______________________________________________________________________________
Rating     60 or 80°C, 30 V.
Conductor     40 AWG minimum, material not specified.
Insulation    Solid or Cellular Polyethylene, 3 mils minimum at any point,          100 mils maximum.  May be irradiated.
Shield     Optional.
Inner Covering    Optional - Extruded PVC, polyamide, TPE, FEP, PVDF, ETFE,              Irradiated P.E., or FRPE or lacquered braids, 2 mils min. at          any point.
Outer Conductor   Optional.
Outer Covering    Optional over braided metal shield, otherwise, Extruded PVC,
           polyamide, FEP, PVDF, ETFE or Lacquered braid, 2 mils min,            at any point.
Standard      Appliance Wiring Material UL 758.
Instructions  Detailed Examination.
to UL
Representative
UL         (4)  Detailed Examination.
*Counter-Check    (12) Horizontal Flame Test.
Program
Marking       General.
Use        Internal Wiring of Electronic Equipment in Class 2 Circuits           only.
cable department - 电缆车间 (0) 投诉
