首页 > 标准共享
[国外标准] DIN VDE 0482-266-1-2001 Common test methods for cables under fire conditions – Test for vertical flame spread of vertically-mounted bunched wires or cables – Part 1: Apparatus
P:2013-12-31 15:35:13
DIN VDE 0482-266-1-2001 Common test methods for cables under fire conditions – Test for vertical flame spread of vertically-mounted bunched wires or cables – Part 1: Apparatus.pdf
multiway - 多向(的),多路(的) (0) 投诉
