首页 > 专业英语|国际贸易
[翻译求助] 请帮忙翻译一下,谢谢,
P:2013-10-23 16:50:30
Single phase: twin type, the colour of the XLPE insulation shall be as indicated in the schedule of prices and both laid in parallel and sheathed with Black XLPE overall. The service main cable shall contain an in-built two core non-polarized pilots for relaying information between themeasurement control unit (MCU) and the customer interface unit (CIU) of the prepaid metering system.
The Sheath shall separate the insulated conductors by a minimum thickness of 3.5mm to provide additional Phase to Neutral/Phase Insulation. In addition to this, a grove of width not less than 1mm shall be provided on the sheath between phase and the Neutral/Phase so that both could be separated easily without bearing the Neutral.
这两段是电缆结构的描述,对其中的  both laid in parallel 不懂,是两根并排平行放置?还是其他什么意思?
an in-built two core non-polarized pilots,这句也不懂
The Sheath shall separate the insulated conductors by a minimum thickness of 3.5mm to provide additional Phase to Neutral/Phase Insulation. In addition to this, a grove of width not less than 1mm shall be provided on the sheath between phase and the Neutral/Phase so that both could be separated easily without bearing the Neutral 这段是没看明白什么意思
有高手帮忙翻译下吗?这里是电缆的结构描述,谢谢 。
short pair twist - 短对绞 (0) 投诉
P:2013-10-24 14:08:38
额,没人来,晕晕
gas supply tank - 供气槽 (0) 投诉
