首页 > 标准共享
[国外标准] ASTM D 412-98A Standard Test Methods for Vulcanized Rubber and Thermoplastic Elastomers-Tension
P:2007-07-13 11:19:37
下面是目录
ASTM D297-98 Standard Test Methods for Rubber Products—Chemical Analysis
ASTM D395-98 Standard Test Methods for Rubber Property—Compression Set
ASTM D412-98 Standard Test Methods for Vulcanized Rubber and Thermoplastic Elastomers—Tension
ASTM D413-98 Standard Test Methods for Rubber Property—Adhesion to Flexible Substrate
ASTM D429-99 Standard Test Methods for Rubber Property—Adhesion to Rigid Substrates
ASTM D430-95 Standard Test Methods for Rubber Deterioration—Dynamic Fatigue
ASTM D454-99 Standard Test Method for Rubber Deterioration by Heat and Air Pressure
ASTM D471-98 Standard Test Method for Rubber Property—Effect of Liquids
ASTM D1052-99 Standard Test Method for Measuring Rubber Deterioration—Cut Growth Using Ross Flexing Apparatus
ASTM D1053-97 Standard Test Methods for Rubber Property—Stiffening at Low Temperatures: Flexible Polymers and Coated Fabrics
ASTM D1054-91 Standard Test Method for Rubber Property—Resilience Using a Rebound Pendulum
ASTM D1076-97 Standard Specification for Rubber—Concentrated, Ammonia Preserved, Creamed, and Centrifuged Natural Latex
ASTM D1148-95 Standard Test Method for Rubber Deterioration—Heat and Ultraviolet Light Discoloration of Light-Colored Surfaces
ASTM D1149-99 Standard Test Method for Rubber Deterioration—Surface Ozone Cracking in a Chamber
ASTM D1171-99 Standard Test Method for Rubber Deterioration—Surface Ozone Cracking Outdoors or Chamber (Triangular Specimens)
ASTM D1229-97 Standard Test Method for Rubber Property—Compression Set at Low Temperatures
ASTM D1278-97 Standard Test Methods for Rubber from Natural Sources—Chemical Analysis
ASTM D1329-98 Standard Test Method for Evaluating Rubber Property—Retraction at Lower Temperatures (TR Test)
ASTM D1349-99 Standard Practice for Rubber—Standard Temperatures For Testing
ASTM D1485-97 Standard Test Methods for Rubber from Natural Sources—Sampling and Sample Preparation
ASTM D1506-99 Standard Test Methods for Carbon Black—Ash Content
ASTM D1508-99 Test Method for Carbon Black, Pelleted Fines and Attrition
ASTM D1509-2000 Standard Test Methods for Carbon Black—Heating Loss
ASTM D1510-99 Standard Test Method for Carbon Black—Iodine Adsorption Number
ASTM D1511-98 Standard Test Method for Carbon Black—Pellet Size Distribution
ASTM D1512-2000 Standard Test Methods for Carbon Black—pH Value
ASTM D1513-99 Standard Test Method for Carbon Black, Pelleted—Pour Density
ASTM D1514-99 Standard Test Method for Carbon Black—Sieve Residue
ASTM D1519-95 Standard Test Method for Rubber Chemicals—Melting Range
ASTM D1566-2000 Standard Terminology Relating to Rubber
ASTM D1618-99 Standard Test Method for Carbon Black Extractables—Transmittance of Toluene Extract
ASTM D1619-99 Standard Test Methods for Carbon Black—Sulfur Content
ASTM D1630-94 Standard Test Method for Rubber Property—Abrasion Resistance (Footwear Abrader)
ASTM D1646-99 Standard Test Methods for Rubber—Viscosity, Stress Relaxation, and Pre-Vulcanization Characteristics (Mooney Viscometer)
ASTM D1765-99 Standard Classification System for Carbon Blacks Used in Rubber Products
ASTM D1766-96 Standard Test Method for Rubber Chemicals—Solubility
ASTM D1799-97 Standard Practice for Carbon Black—Sampling Packaged Shipments
ASTM D1817-96 Standard Test Method for Rubber Chemicals—Density
ASTM D1900-98 Standard Practice for Carbon Black—Sampling Bulk Shipments
ASTM D1917-97 Standard Test Methods for Rubber Property—Shrinkage of Raw and Compounded Hot-Polymerized Styrene-Butadiene Rubber (SBR)
ASTM D1937-98 Standard Test Method for Carbon Black, Pelleted—Mass Strength
ASTM D1991-96 Standard Test Method for Rubber Chemicals—2-Mercaptobenzothiazole (MBT)—Assay
ASTM D1992-97 Standard Guide for Testing Synthetic Plasticizers Used in Rubber
ASTM D1993-97 Standard Test Method for Precipitated Silica-Surface Area by Multipoint BET Nitrogen Adsorption
ASTM D2000-2004 Standard Classification System for Rubber Products in Automotive Applications
ASTM D2084-95 Standard Test Method for Rubber Property—Vulcanization Using Oscillating Disk Cure Meter
ASTM D2136-94 Standard Test Method for Coated Fabrics—Low-Temperature Bend Test
ASTM D2137-2000 Standard Test Methods for Rubber Property—Brittleness Point of Flexible Polymers and Coated Fabrics
ASTM D2226-98 Standard Classification for Various Types of Petroleum Oils for Rubber Compounding Use
ASTM D2227-96 Standard Specification for Natural Rubber (NR) Technical Grades
ASTM D2228-94 Standard Test Method for Rubber Property—Abrasion Resistance (Pico Abrader)
ASTM D2230-96 Standard Test Method for Rubber Property—Extrudability of Unvulcanized Compounds
ASTM D2220-97 Standard Test Method for Rubber Property—Durometer Hardness
ASTM D2414-2000 Standard Test Method for Carbon Black—n–Dibutyl Phthalate Absorption Number
ASTM D2449-95 Standard Specification for Rubber Bales From Natural Sources—Limit on Coating
ASTM D2632-96 Standard Test Method for Rubber Property—Resilience by Vertical Rebound
ASTM D2663-2000 Standard Test Methods for Carbon Black—Dispersion in Rubber
ASTM D2702-98 Standard Practice for Rubber Chemicals—Determination of Infrared Absorption Characteristics
ASTM D2703-95 Standard Practice for Rubber Chemicals—Determination of Ultraviolet Absorbance Characteristics
ASTM D3053-99 Standard Terminology Relating to Carbon Black
ASTM D3137-94 Standard Test Method for Rubber Property—Hydrolytic Stability
ASTM D3156-96 Standard Practice for Rubber—Chromatographic Analysis of Antidegradants (Antioxidants, Antiozonants and Stabilizers)
ASTM D3157-95 Standard Test Method for Rubber from Natural Sources—Color
ASTM D3182-94 Standard Practice for Rubber—Materials, Equipment, and Procedures for Mixing Standard Compounds and Preparing Standard Vulcanized Sheets
ASTM D3183-98 Standard Practice for Rubber—Preparation of Pieces for Test Purposes from Products
ASTM D3184-95 Standard Test Methods for Rubber—Evaluation of NR (Natural Rubber)
ASTM D3185-99 Standard Test Methods for Rubber—Evaluation of SBR (Styrene-Butadiene Rubber) Including Mixtures With Oil
ASTM D3186-97 Standard Test Methods for Rubber—Evaluation of SBR (Styrene-Butadiene Rubber) Mixed With Carbon Black or Carbon Black and Oil
ASTM D3187-95 Standard Test Methods for Rubber—Evaluation of NBR (Acrylonitrile-Butadiene Rubber)
ASTM D3188-95 Standard Test Methods for Rubber—Evaluation of IIR (Isobutene-Isoprene Rubber)
ASTM D3189-99 Standard Test Methods for Rubber—Evaluation of Solution BR (Polybutadiene Rubber)
ASTM D3190-96 Standard Test Method for Rubber—Evaluation of Chloroprene Rubber (CR)
ASTM D3191-97 Standard Test Methods for Carbon Black in SBR (Styrene-Butadiene Rubber)—Recipe and Evaluation Procedures
ASTM D3192-97 Standard Test Methods for Carbon Black Evaluation in NR (Natural Rubber)
ASTM D3194-99 Standard Test Method for Rubber From Natural Sources—Plasticity Retention Index (PRI)
ASTM D3265-99 Standard Test Method for Carbon Black—Tint Strength
ASTM D3313-99 Standard Test Method for Carbon Black—Individual Pellet Hardness
ASTM D3314-97 Standard Test Method for Rubber—Chemical Analysis for Polystyrene Blocks In SBR (Styrene-Butadiene Rubber) and Styrene-Reinforced Latices
ASTM D3324-99 Standard Practice for Carbon Black—Improving Test Reproducibility Using ASTM Reference Blacks
ASTM D3346-95 Standard Test Methods for Rubber Property—Processability of SBR (Styrene-Butadiene Rubber) With the Mooney Viscometer
ASTM D3395-99 Standard Test Methods for Rubber Deterioration—Dynamic Ozone Cracking in a Chamber
ASTM D3403-97 Standard Test Methods for Rubber—Evaluation of IR (Isoprene Rubber)
ASTM D3452-98 Standard Practice for Rubber—Identification by Pyrolysis-Gas Chromatography
ASTM D3484-97 Standard Test Methods for Rubber—Evaluation of Oil-Extended Solution BR (Polybutadiene Rubber)
ASTM D3493-99 Standard Test Method for Carbon Black—n-Dibutyl Phthalate Absorption Number of Compressed Sample
ASTM D3533-95 Standard Test Method for Rubber—Nitrogen Content
ASTM D3566-96 Standard Practice for Rubber—Determination of Bromine in the Presence of Chlorine by Oxygen Combustion
ASTM D3568-98 Standard Test Methods for Rubber—Evaluation of EPDM (Ethylene Propylene Diene Terpolymers) Including Mixtures With Oil
ASTM D3616-95 Standard Test Method for Rubber, Raw—Determination of Gel, Swelling Index, and Dilute Solution Viscosity
ASTM D3629-99 Standard Test Method for Rubber Property—Cut Growth Resistance
ASTM D3677-95 Standard Test Methods for Rubber—Identification by Infrared Spectrophotometry
ASTM D3765-99 Standard Test Method for Carbon Black—CTAB (Cetyltrimethylammonium Bromide) Surface Area
ASTM D3767-96 Standard Practice for Rubber—Measurement of Dimensions
ASTM D3847-96 Standard Practice for Rubber—Directions for Achieving Subnormal Test Temperatures
ASTM D3848-98 Standard Test Methods for Rubber—Evaluation of NBR (Acrylonitrile-Butadiene Copolymers) Mixed With Carbon Black
ASTM D3849-2000 Standard Test Method for Carbon Black — Primary Aggregate Dimensions from Electron Microscope Image Analysis
ASTM D3853-97 Standard Terminology Relating to Rubber and Rubber Latices—Abbreviations for Chemicals Used in Compounding
ASTM D3896-95 Standard Practice for Rubber From Synthetic Sources—Sampling
ASTM D3900-95 Standard Test Methods for Rubber Raw—Determination of Ethylene Units in EPM (Ethylene-Propylene Copolymers) and EPDM (Ethylene-Propylene-Diene Terpolymers)
ASTM D3958-95 Standard Test Methods for Rubber—Evaluation of BIIR and CIIR (Halogenated Isobutene—Isoprene Rubber)
ASTM D4004-98 Standard Test Methods for Rubber—Determination of Metal Content by Flame Atomic Absorption (AAS) Analysis
ASTM D4026-97 Standard Test Method for Rubber Latex—Styrene-Butadiene Copolymer—Determination of Residual Styrene
ASTM D4075-97 Standard Test Methods for Compounding Materials—Flame Atomic Absorption Technique—Determination of Metals
ASTM D4122-96 Standard Practice for Carbon Black—Evaluation of an Industry Reference Black
ASTM D4295-99 Standard Classification for Rubber Compounding Materials—Zinc Oxide
ASTM D4315-94 Standard Test Methods for Rubber Compounding Material—Zinc Oxide
ASTM D4482-99 Standard Test Method for Rubber Property—Extension Cycling Fatigue
ASTM D4483-99 Standard Practice for Determining Precision for Test Method Standards in the Rubber and Carbon Black Industries
ASTM D4527-99 Standard Test Method for Carbon Black—Solvent Extractables
ASTM D4528-98 Standard Classification for Rubber Compounding Materials—Sulfur
ASTM D4569-98 Standard Test Method for Rubber Chemicals—Determination of Acidity in Sulfur
ASTM D4570-98 Standard Test Method for Rubber Chemicals—Determination of Particle Size of Sulfur by Sieving (Dry)
ASTM D4571-98 Standard Test Methods for Rubber Chemicals—Determination of Volatile Material
ASTM D4572-99 Standard Test Method for Rubber Chemicals—Wet Sieve Analysis of Sulfur
ASTM D4573-98 Standard Test Method for Rubber Chemicals—Determination of Oil Content in Oil- Treated Sulfur
ASTM D4574-98 Standard Test Methods for Rubber Chemicals—Determination of Ash Content
ASTM D4575-99 Standard Test Methods for Rubber Deterioration—Reference and Alternative Method(s) for Determining Ozone Level in Laboratory Test Chambers
ASTM D4578-98 Standard Test Methods for Rubber Chemicals—Determination of Percent Insoluble Sulfur by Solvent Extraction
ASTM D4583-99 Standard Practice for Carbon Black—Calculation of Process Indexes From an Analysis of Process Control Data
ASTM D4620-98 Standard Test Method for Evaluating the Effective Surface Area of Zinc Oxide in Rubber
ASTM D4676-94 Standard Classification for Rubber Compounding Materials—Antidegradents
ASTM D4677-98 Standard Classification for Rubber Compounding Materials—Titanium Dioxide
ASTM D4678-94 Standard Practice for Rubber—Preparation, Testing, Acceptance, Documentation, and Use of Reference Materials
ASTM D4817-99 Standard Classification for Rubber Compounding Materials—Stearic Acid
ASTM D4818-99 Standard Classification for Rubber Compounding Materials—Vulcanization Accelerators
ASTM D4820-99 Standard Test Methods for Carbon Black—Surface Area by Multipoint B.E.T. Nitrogen Adsorption
ASTM D4821-99 Standard Guide for Carbon Black—Validation of Test Method Precision and Bias
ASTM D4924-99 Standard Classification for Petroleum Waxes for Use in Rubber Compounding
ASTM D4934-98 Standard Test Method for Rubber Compounding Materials: 2-Benzothiazyl Sulfenamide Accelerators—Insolubles
ASTM D4936-96 Standard Test Method for Mercaptobenzothiazole Sulfenamide Assay by Reduction/Titration
ASTM D4937-96 Standard Test Method for p-Phenylenediamine Antidegradants Purity by Gas Chromatography
computerized process control system - 计算机化工艺控制系统 (0) 投诉
P:2008-01-18 13:57:50
老兄:能不能发一份以下标准,非常感谢!或直接发到我的邮箱:duqishan1202@163.com
ASTM470
ASTM1047
ASTM1248
ASTM1351
ASTM6096
ASTM2655
ASTM3554
ASTM3555
multiple-pass drum twisting machine - 多头盘式绞线机,多道盘绞机 (0) 投诉
18
