[问题求助] SCART TO 3.5MM STEREO PLUG (4 POLES)接線方法
P:2007-07-11 17:59:13
那位朋友知SCART TO  3.5MM STEREO PLUG (4 POLES)接線方法,請提供,謝謝!
AO - atomic oxygen原子氧 (0) 投诉
P:2007-07-12 07:59:52
是RCA吧。我到是见过能接左右声道的RCA,按PIN点定义就当可以接3。5。不过不确认。
direct burial cable - 直埋电缆 (0) 投诉
P:2007-07-13 12:46:53
可是我也不能確認啊
cylinder - 体筒(挤出机的),螺筒 (0) 投诉
P:2007-07-13 13:29:58
Scart Pin 點定義:
Pin
Name
Description
Signal Level
Impedance
AOR
Audio Out Right
0.5 V rms
AIR
Audio In Right
0.5 V rms
AOL
Audio Out Left + Mono
0.5 V rms
AGND
Audio Ground
B GND
RGB Blue Ground
AIL
Audio In Left + Mono
0.5 V rms
B
RGB Blue
0.7 V
75 ohm
SWTCH
Audio/RGB switch / 16:9
Function Select(A/V Control)
High(9.5-12V)-A/V mode, Mid(5-8V)-wide-screen,
Low(0-2V)-TV mode
G GND
RGB Green Ground
CLKOUT
Data 2: Clock pulse OUT
G
RGB Green
0.7 V
75 ohm
DATA
Data 1: Data  OUT
R GND
RGB Red Ground
GND
Ground(Data or Blanking)
R
RGB Red ( Chrominance In or Out)
0.7 V (Chrominance: 0.3 V burst)
75 ohm
16
BLNK
Blanking Signal
1-3 V=RGB, 0-0.4 V=Composite
75 ohm
17
VGND
Video Ground
18
GND
Ground(Blanking Signal or Video)
19
VOUT
Composite Video Out/ Luminance Out
1 V including sync
75 ohm
20
VIN
Composite Video In / Luminance In
1 V including sync
75 ohm
21
SHIELD
Ground/Shield (Chassis)
high precision gas dosing unit - 高精度气体分配装置,高精度气体剂量分配装置 (0) 投诉
