首页 > 标准共享
[国外标准] BS EN 60332-1-1:2004 Tests on electric and optical fibre cables under fire conditions Part 1-1:Test for vertical flame propagation for a single insulated wire or cable Apparatus
P:2013-09-05 14:46:37
BS EN 60332-1-1:2004 Tests on electric and optical fibre cables under fire conditions Part 1-1:Test for vertical flame propagation for a single insulated wire or cable Apparatus.pdf
multiplex - 多路传输,多路复用 (0) 投诉
