[二手市场] 设备转让台湾项全牌电线电缆编织机 16锭/2头 4台 24锭/1头 6台
P:2013-07-07 20:07:55
东莞市企石镇电线厂 13669830283 吴生
供应16锭高速编织机、屏蔽线、同轴线编织机
Electric wire and cable braiding machine
功率:0.55*2 | 型号:GB16-2-2 | 电压:220v |
纬度范围:2-26目 | 品牌:GB冠博精机 | 种类:电线编织机 |
加工定制:是 | 速度:360RPM |
双头双电16#编织机为独立传动,可同时生产两条不同型号的线材,开停机互不干涉,生产灵活,生产效率高,电线编织机全系列均采用新式的走马式结构,优势突出. 主要产品有:同轴线、屏蔽线、控制电线、波铝箔线等
GB16# braiding machine with 2 heads and 2 motors can produce two different kinds of wire or cable by separate transmission. Each motor can run by itself without interference. The whole series has adapted the new-style vertical GB structure which has the priority as followings:
1、机器结构紧凑、合理,有效节约场地;
Reasonable structure and less space needed
2、操作便捷,省人省力,对操作人员要求低
Easy operation and less labor needed
3、 机械选材考究及加工处理精细,整机使用寿命更长;
Top-class parts and long service life
4、电器配制均衡,总功率小,节省用电;
Low HP and low electricity cost
5、采用变频器调速,具有断线自动停车功能,具有短距倒车功能,可提高编织品质;
Applications of transducer, automatic stop unit for wire breaking and rolling-back unit help improve the machine’s performance.
6、编织过程中不甩油,特别适用于透明线材的编织;
In the process of braiding, there is no spraying oil that is especially suitable for the braiding of lucency wires.
7、纱管容量大,张力稳定易调节,提高生产效率;
Bigger volume of bobbin and easier adjustment of strain.
8、配件损耗低,整机易维护,其使用与维修成本明显低于卧式高速机;
Durable parts and easy to maintain the whole machine: Maintenance cost is much lower than that of horizontal high speed braiding machine.
9、应用范围广,具有金属丝与化纤纱线混合编织功能;
Vast application scope (Include the function of hybrid braiding wire & chemical fiber)
Loomwire - 鲁姆线(一种全塑绝缘电线,美NationalElecProducts公司的商品名称) (0) 投诉
