首页 > 架空线 裸电线
[裸电线] 谁有铝包钢绞线的结构和近似性能
P:2013-07-11 08:22:52
| 0.7854 | g/cm3 | IACS | 截面铝比 | GPa | 膨胀系数 | 电阻温度系数 | |
| LB14 | 7.14 | 14% | 123.15 | 13% | 170 | 12.0 | 0.0034 |
| LB20A | 6.59 | 20.3% | 84.80 | 25% | 162 | 13.0 | 0.0036 |
| LB20B | 6.53 | 20.3% | 84.80 | 25% | 155 | 12.6 | 0.0036 |
| LB23 | 6.27 | 23% | 74.96 | 30% | 149 | 12.9 | 0.0036 |
| LB27 | 5.91 | 27% | 63.86 | 37% | 140 | 13.4 | 0.0036 |
| LB30 | 5.61 | 30% | 57.47 | 43% | 132 | 13.8 | 0.0038 |
| LB35 | 5.15 | 35% | 49.26 | 52% | 122 | 14.5 | 0.0039 |
| LB40 | 4.64 | 40% | 43.10 | 62% | 109 | 15.5 | 0.0040 |
endplate - 端板,侧板 (0) 投诉
P:2013-07-11 08:24:30
| 铝包钢绞线单位长度重量表 | |||||||||||
| 规格 | 结构 | 外径 | 计算重量 kg/km | ||||||||
| mm2 | 根 | mm | mm | JLB14 | JLB20A | JLB2B | JLB23 | JLB27 | JLB30 | JLB35 | JLB40 |
| 35 | 7 | 2.50 | 7.50 | 247.8 | 228.7 | 226.6 | 217.6 | / | / | / | |
| 40 | 7 | 2.75 | 8.25 | 299.8 | 276.7 | 274.2 | 263.3 | / | / | / | |
| 45 | 7 | 2.90 | 8.70 | 333.4 | 307.7 | 304.9 | 292.8 | 276.0 | 262.0 | / | |
| 50 | 7 | 3.00 | 9.00 | 356.8 | 329.3 | 326.3 | 313.3 | 295.4 | 280.4 | 257.4 | 231.9 |
| 55 | 7 | 3.20 | 9.60 | 406.0 | 374.7 | 371.3 | 356.5 | 336.0 | 319.0 | 292.8 | 263.8 |
| 65 | 7 | 3.50 | 10.50 | 485.7 | 448.3 | 444.2 | 426.5 | 402.0 | 381.6 | 350.3 | 315.6 |
| 70 | 7 | 3.60 | 10.80 | 513.8 | 474.2 | 469.9 | 451.2 | 425.3 | 403.7 | 370.6 | 333.9 |
| 80 | 7 | 3.80 | 11.40 | 572.5 | 528.4 | 523.6 | 502.7 | 473.9 | 449.8 | 412.9 | 372.0 |
| 95 | 7 | 4.16 | 12.48 | 686.1 | 633.3 | 627.5 | 602.5 | 567.9 | 539.1 | 494.9 | 445.9 |
| 100 | 19 | 2.60 | 13.00 | 730.3 | 674.1 | 665.3 | 641.4 | 604.5 | 573.8 | 526.8 | 474.6 |
| 120 | 19 | 2.85 | 14.25 | 877.5 | 809.9 | 799.4 | 770.6 | 726.4 | 689.5 | 633.0 | 570.3 |
| 150 | 19 | 3.15 | 15.75 | 1072.0 | 989.4 | 976.6 | 941.4 | 887.3 | 842.3 | 773.2 | 696.7 |
| 185 | 19 | 3.50 | 17.50 | 1323.5 | 1221.5 | 1205.6 | 1162.2 | 1095.5 | 1039.9 | 954.6 | 860.1 |
| 210 | 19 | 3.75 | 18.75 | 1519.3 | 1402.3 | 1384.0 | 1334.2 | 1257.6 | 1193.7 | 1095.9 | 987.3 |
| 240 | 19 | 4.00 | 20.00 | 1728.6 | 1595.5 | 1574.7 | 1518.0 | 1430.8 | 1358.2 | 1246.8 | 1123.4 |
| 300 | 37 | 3.20 | 22.40 | 2167.2 | 2000.2 | 1962.6 | 1903.1 | 1793.8 | 1702.8 | 1563.1 | 1408.4 |
| 380 | 37 | 3.60 | 25.20 | 2742.8 | 2531.5 | 2483.9 | 2408.6 | 2270.3 | 2155.1 | 1978.4 | 1782.4 |
| 420 | 37 | 3.80 | 26.60 | 3056.0 | 2820.6 | 2767.5 | 2683.7 | 2529.6 | 2401.2 | 2204.3 | 1986.0 |
| 465 | 37 | 4.00 | 28.00 | 3386.2 | 3125.3 | 3066.5 | 2973.6 | 2802.9 | 2660.6 | 2442.4 | 2200.5 |
| 510 | 37 | 4.20 | 29.40 | 3733.3 | 3445.7 | 3380.8 | 3278.4 | 3090.1 | 2933.3 | 2692.8 | 2426.1 |
| 590 | 37 | 4.50 | 31.50 | / | / | / | 3763.4 | 3547.4 | 3367.3 | 3091.2 | 2785.1 |
| 670 | 37 | 4.80 | 33.60 | / | / | / | 4282.0 | 4036.1 | 3831.2 | 3517.1 | 3168.8 |
[wanggx 在 2013-7-11 11:26:25 编辑过]
service access point identifier - 业务接入点识别符 (0) 投诉
P:2013-11-28 11:05:32
铝包钢绞线
供应铝包钢绞线LBGJ、JLB1A、JLB1B、JLB2、JLB3、JLB4 标称截面钢 Nominal Section Steel 规格号 Size 面积Area mm2 单线根数 Single Line Nos 直径/mm Diameter 单位长度质量Weight(kg/km) 额定拉断力/kN Rated Breaking force 直流电阻 DC Resistance (20℃) Ω/km 单线 Single Line 绞线 Strand JLB1A JLB1B JLB1A JLB1B 15 4 12 7 1.48 4.43 80.1 79.4 16.08 15.84 7.1592 20 6.3 18.9 7 1.85 5.56 126.1 125.0 25.33 24.95 4.5455 30 10 30 7 2.34 7.01 200.3 198.5 40.20 39.60 2.8637 35 12.5 37.5 7 2.61 7.84 250.4 248.1 50.25 49.50 2.2910 50 16 48 7 2.95 8.86 320.5 248.1 64.32 63.36 1.7898 75 25 75 7 3.69 11.08 500.7 317.5 93.75 99.00 1.1455 120 40 120 7 4.67 14.02 801.2 496.2 132.00 158.40 0.7159 120 40 120 19 2.84 14.18 805.0 793.9 160.80 158.40 0.7194 200 63 189 19 3.56 17.79 1267.9 1256.4 240.03 249.48 0.4568 300 100 300 37 3.21 22.49 2017.3 1999.0 402.00 396.00 0.2884 350 125 375 37 3.59 15.15 2521.7 2498.3 476.25 495.00 0.2307 450 160 480 37 4.06 28.45 3227.7 3198.3 580.80 633.00 0.1803 600 200 600 37 4.54 31.81 4034.7 3997.9 684.00 792.00 0.1442 600 200 600 61 3.54 31.85 4040.6 4003.8 762.00 792.00 0.1444
郑州市华威金属材料有限公司有五十余年的电线电缆生产历史,专业生产制造铝包钢丝、铝包钢绞线、铝包钢芯铝绞线、铝包钢承力索、钢芯铝绞线、铝合金绞线,电力电缆、铜绞线,镁铜合金丝等产品,质量上乘、广受赞誉!
铝包钢绞线定义:
定根数的铝包钢单丝绞制而成;铝包钢单丝是一种将铝连续均匀包覆在钢芯上的双金属丝,它兼有导电性能好,耐腐蚀,高频传输性能好以及钢的强度高等优点。
铝包钢绞线用
用于大跨越输电线,良导体避雷地线,光纤复合架空地线,电线架设绞线,防冰雪导线,倍容导线,自阻尼导线,电气化铁路接触网承力索。
铝包钢绞线按导电率分为:20AC、23AC、27AC、30AC、33AC、40AC六个组别,其相应的导电率为20.3%、23%、27%、30%、33%和40%IACS.
铝包钢绞线的代号为: LBGJ、JLB1A、JLB20
铝包钢绞线JLB1规格表
销售经理:晋经理
邮箱:13733825789@163.com
QQ:896924260
电话:0371-66305222
手机:13733825789
邮编:450007
公司网址:www.--zzcables.com
单位名称:郑州市华威金属材料有限公司
单位地址:郑州市管城区东明路58号
similars - 相似导线(电机内的导线,在磁场中相差180度) (0) 投诉
