首页 > 国外线缆
[问题求助] 请教2474线的绝缘厚度要求是多少啊
P:2007-06-28 10:01:13
请教2474线的绝缘厚度要求是多少啊!间距有何要求吗!
metallic-coated steel wire - 金属涂层钢线 (0) 投诉
P:2007-06-28 10:10:51
Style 2474    Flat Ribbon-Type Cable.
Rating     105°C, 600 V.
Insulated     Labeled or compling with manufacturer's AWM
Singles       Procedure having a minimum rating of 105°C, 600 V
Instructions  The average and min insulation thickness along the
to UL         ripped edges of the insulated conductor shall be
Representative       30 and 27 mils respectively.
           Tensile strength and elongation of insulation on
              at least 25 percent (with not less than one light
              and one dark color) of the individual insulation
              conductors by ripping the finished cable, same as
*             for Class 43.
hot-forming - 热成型 (0) 投诉
