[供应信息] 橡皮绝缘家用电源电线JYEFQ、JYEFQA、JYEMQ、JYEMQA,JYEFZ、JYEFZA、J
P:2013-04-03 16:52:06
| 橡皮绝缘家用电源电线JYEFQ、JYEFQA、JYEMQ、JYEMQA,JYEFZ、JYEFZA、JYEMZ、JYEMZA Rubber Insulated Appliance Electrical Source Power Supply Wires |
| 产品标准 Standard 橡皮绝缘家用电源电线按照Q/320382DCE019-2000《额定电压300/500V以下橡皮绝缘家用电源电线》生产,同时还根据用户需要按GB 5013、JB8735、国际电工委员会推荐标准IEC、英国标准、德国标准及美国标准生产。 The product is manufactured according to the standard of Q/320383DCE019-2000,and GB5013-1997、JB8735-1998、or IEC、BS、DIN、ICEA、upon request. 适用范围 Applications 使用特性 Operating characteristics 电缆的型号 Type of cable |
| 注:产品型号后边有“A”为特软导体 The “A” after every expresses special flexible conductor |
| 橡皮绝缘家用电源电线生产范围 Production range of cable |
| 结构尺寸及主要技术参数 Construction and main technical data ·天然丁苯绝缘氯丁护套轻型家用电源电线 NR/SBR insulated ,neoprene (CR) jacketed appliance electrical source power supply light duty wires |
| ·天然丁苯绝缘氯化聚乙烯护套轻型家用电源电线 NR/SBR insulated ,CPE neoprene jacketed appliance electrical source power supply light duty wires |
| ·乙丙绝缘氯丁护套轻型家用电源电线 EPT insulated , neoprene (CR)jacketed appliance electrical source power supply light duty wires |
| ·乙丙绝缘氯化聚乙烯护套轻型家用电源电线 EPT insulated , CPE jacketed appliance electrical source power supply light duty wires |
| ·天然丁苯绝缘氯丁护套中型家用电源电线 NR/SBR insulated , neoprene (CR)jacketed appliance electrical source power supply middle sized wires |
| ·天然丁苯绝缘氯化聚乙烯护套中型家用电源电线 NR/SBR insulated , CPE jacketed appliance electrical source power supply middle sized wires |
| ·乙丙绝缘氯丁护套中型家用电源电线 EPT insulated , neoprene (CR)jacketed appliance electrical source power supply middle sized wires |
| ·乙丙绝缘氯丁护套中型家用电源电线 EPT insulated , neoprene (CR) jacketed appliance electrical source power supply middle sized wires |
| ·乙丙绝缘氯化聚乙烯护套中型家用电源电缆 EPT insulate , CPE jacketed appliance electrical source power supply middle sized wires |
| 载流量 Current carrying capacity |
| 不同环境温度下载流量修正系数 Rating factors of current rating for ambient air temperature |
http://www.--anhdl.com
copolymerization - 共聚作用 (0) 投诉
