首页 > 国外线缆
[问题求助] ul1972和UL1598的标准谁能给我一份
P:2013-03-14 21:42:34
ul1972和UL1598的标准谁能给我一份,谢谢了。邮箱liong1979@126.com
mil length - 密尔长度(表示随机长度,也称randomlength) (0) 投诉
P:2014-01-14 14:28:01
APPLIANCE WIRING MATERIAL
Subj.758Section 1Page 1972Issued:1986-01-17
Revised:2012-03-07
Style 1972Single conductor with extruded insulation.
Rating80 deg C, 30 Vac.
Conductor36 AWG minimum, solid or stranded
InsulationExtruded PVC consists of two layers, combined thickness with 4 mils minimum at any point.
StandardAppliance Wiring Material UL 758.
MarkingGeneral.
UseFor further processing into Cables.
UL and the UL Logo are trademarks of UL LLC © 2014
PLL - phase locked loop相位锁定环,锁相环,同步环 (0) 投诉
P:2014-01-14 14:46:33
Subj.758Section 1Page 1598Issued:1973-07-11
Revised:2012-03-09
Style 1598Single Conductor with Extruded Insulation
Rating60, 80 deg C, 30 Vac.
Conductor50 AWG minimum.
InsulationExtruded PE or extruded foamed PE. 2 to 100 mils thickness. May be crosslinked.
ShieldOptional.
CoveringOptional - Extruded PVC, polyamide(Nylon) or polyester or polyethylene or flame retardant polyethylene, approximately 2 mils thick, or lacquered braid.
MarkingGeneral.
UseFor further processing in jacketed cables.
</div>
[koulf 在 2014-1-14 14:47:02 编辑过]
haul-off unit - 牵引装置 (0) 投诉
