首页 > 国外线缆
[问题求助] 请朋友们告知下UL10455 具体规范?
P:2013-03-14 13:33:42
请朋友们告知下UL10455 具体规范
field telephone wire - 野外用电话线,野战电话线 (0) 投诉
P:2013-03-14 13:36:30
APPLIANCE WIRING MATERIAL
Subj.758Section 1Page 10455Issued:1999-10-29
Revised:2012-08-24
Style 10455Single Conductor Cable with Extruded Non-integral Jacket.
Rating90 deg C, 600 Vac, Cable flame.
Conductor30 AWG min. solid or stranded round.
InsulationLabeled or complying with Manufacturer's AWM Procedure.
ShieldOptional.
CoveringOptional. A barrier layer if employed, may be a fibrous wrap, serving or braid; Paper; Nylon: oriented Polyethylene terephthalate; or a thermoplastic tape wrap.
JacketExtruded PVC
dia in inches of 0.700 or less30 mils min average24 mils minimum at any point
1.000 dia or less45 avg36 min
1.001-1.500 dia60 avg48 min
1.501-2.500 dia80 avg64 min
2.501-4.00 dia110 avg88 min
StandardAppliance Wiring Material UL 758.
MarkingGeneral.
UseInternal wiring or external wiring.
UL and the UL Logo are trademarks of UL LLC © 2013
coil-loaded cable - 加感电缆 (0) 投诉
P:2013-03-14 15:52:41
谢谢。
seven-strand wire - 七股绞线 (0) 投诉
P:2013-03-19 10:14:50
主要还是依照Page 10455要求,
很明确的!
temperature increase - 温度升高,温升 (0) 投诉
