首页 > 国外线缆
[问题求助] 求助,谁有UL20237的详细资料啊
P:2013-02-21 16:56:09
| APPLIANCE WIRING MATERIAL | ![]() | ||||
| Subj.758 | Section 2 | Page 20237 | Issued:1984-08-24 |
| Revised:2008-05-27 | |||
| Style 20237 | Jacketed Cable | |
| Rating | 125 deg C, 300 Vac, Cable flame. |
| Conductor | 36 AWG min. Solid or Stranded. |
| Insulation | Labeled or complying with manufacturer's AWM Procedure. The designations of all styles of individual conductors used in making up the cable assembly shall be available. |
| Assembly | Two or more individually insulated conductors or groups of insulated conductors cabled together to form a round cable. A flat or oval cable may also be constructed with not more than three rows of single conductors or groups of conductors. The length of lay of the twisted conductors or groups is not specified. Fillers may be used in a cable but are not required. A barrier layer, if employed, may be a fibrous wrap serving, or braid; paper; nylon; oriented polyethylene terephthalate; or thermoplastic-tape wrap. Such a barrier layer would serve to protect the cable during further processing and would be applied immediately over the twisted assembly of individual conductors or groups of conductors. |
| Shield | Optional. |
| Covering | Optional - 4 mil or heavier wall of PVC or other thermoplastic covering may be extruded over the conductor assembly or groups of conductors (with or without shields). |
| Jacket | TPE - See Facing Page for Compound Designation |
| dia of cable under jacket of 0.700 inches or less* | 30 mils min average | 24 mils minimum at any point |
| 0.701-1.000 dia | 45 avg | 36 min |
| 1.001-1.500 dia | 60 avg | 48 min |
| 1.501-2.500 dia | 80 avg | 64 min |
| 2.501-4.000 dia | 110 avg | 88 min |
| 4.001 dia and larger | 140 avg | 112 min |
| Standard | Appliance Wiring Material UL 758. |
| Marking | General. |
| Use | External interconnection of electronic equipment. |
UL and the UL Logo are trademarks of UL LLC © 2013
water-cooled die holder - 水冷却模架 (0) 投诉
