[技术资料] 降低射频同轴接器电压驻波比的方法(线缆装接等后续加工)
P:2013-02-02 14:06:52
<DIV class=O v:shape="_x0000_s1026"><DIV style="mso-line-spacing: '120 0 0'; mso-char-wrap: 1; mso-kinsoku-overflow: 1">1、引言 </DIV><DIV style="mso-line-spacing: '120 0 0'; mso-char-wrap: 1; mso-kinsoku-overflow: 1">2、影响射频同轴连接器VSWR的因素 </DIV><DIV style="mso-line-spacing: '120 0 0'; mso-char-wrap: 1; mso-kinsoku-overflow: 1">2.1设计时,应用射频连接器基本设计三原则不当带来的影响。 </DIV><DIV style="mso-line-spacing: '120 0 0'; mso-char-wrap: 1; mso-kinsoku-overflow: 1">2.2结构参数偏差对VSWR的影响。 </DIV><DIV style="mso-line-spacing: '120 0 0'; mso-char-wrap: 1; mso-kinsoku-overflow: 1">2.3绝缘支撑的轴向位置和结构设计对特性阻抗的影响。 </DIV><DIV style="mso-line-spacing: '120 0 0'; mso-char-wrap: 1; mso-kinsoku-overflow: 1">2.4过渡设计 </DIV><DIV style="mso-line-spacing: '120 0 0'; mso-char-wrap: 1; mso-kinsoku-overflow: 1">2.5表面粗糙度的影响 </DIV><DIV style="mso-line-spacing: '120 0 0'; mso-char-wrap: 1; mso-kinsoku-overflow: 1">2.6导体镀涂的影响 </DIV><DIV style="mso-line-spacing: '120 0 0'; mso-char-wrap: 1; mso-kinsoku-overflow: 1">2.7装配不当带来的影响 </DIV><DIV style="mso-line-spacing: '120 0 0'; mso-char-wrap: 1; mso-kinsoku-overflow: 1">2.8测试系统的缺陷带来的影响 </DIV><DIV style="mso-line-spacing: '120 0 0'; mso-char-wrap: 1; mso-kinsoku-overflow: 1">2.9生产加工不当漏检带来的影响 </DIV><DIV style="mso-line-spacing: '120 0 0'; mso-char-wrap: 1; mso-kinsoku-overflow: 1">3、降低射频连接器VSWR的途径和措施 </DIV><DIV style="mso-line-spacing: '120 0 0'; mso-char-wrap: 1; mso-kinsoku-overflow: 1">3.1.做好设计控制,体现降低VSWR措施 </DIV><DIV style="mso-line-spacing: '120 0 0'; mso-char-wrap: 1; mso-kinsoku-overflow: 1">3.2.老产品改进 </DIV><DIV style="mso-line-spacing: '120 0 0'; mso-char-wrap: 1; mso-kinsoku-overflow: 1">3.3.生产中查找影响VSWR的因素,确定整改措施,保证VSWR性能 </DIV><DIV style="mso-line-spacing: '120 0 0'; mso-char-wrap: 1; mso-kinsoku-overflow: 1"> </DIV><DIV style="mso-line-spacing: '120 0 0'; mso-char-wrap: 1; mso-kinsoku-overflow: 1">生产实用型工艺文件,内有详细的工艺细节、设计图、数据、解释等</DIV><DIV style="mso-line-spacing: '100 50 0'; mso-char-wrap: 1; mso-kinsoku-overflow: 1"></DIV></DIV>
auto-track annealing system - 自动轨道式退火装置 (0) 投诉
P:2013-02-02 14:17:21
1、引言
2、影响射频同轴连接器VSWR的因素
2.2结构参数偏差对VSWR的影响。
2.4过渡设计
2.5表面粗糙度的影响
2.6导体镀涂的影响
2.7装配不当带来的影响
2.8测试系统的缺陷带来的影响
2.9生产加工不当漏检带来的影响
3、降低射频连接器VSWR的途径和措施
3.2.老产品改进
<DIV style="mso-line-spacing: '100 50 0'; mso-char-wrap: 1; mso-kinsoku-overflow: 1">4.结束语 </DIV><DIV style="mso-line-spacing: '100 50 0'; mso-char-wrap: 1; mso-kinsoku-overflow: 1"> </DIV><DIV style="mso-line-spacing: '100 50 0'; mso-char-wrap: 1; mso-kinsoku-overflow: 1">生产实用型工艺文件,内有详细的工艺细节、设计图、数据、解释等</DIV><DIV style="mso-line-spacing: '100 50 0'; mso-char-wrap: 1; mso-kinsoku-overflow: 1"> </DIV><DIV style="mso-line-spacing: '100 50 0'; mso-char-wrap: 1; mso-kinsoku-overflow: 1"> </DIV><DIV style="mso-line-spacing: '100 50 0'; mso-char-wrap: 1; mso-kinsoku-overflow: 1">直接复制过来怎么会成这样了</DIV></DIV>
cable support hose system - 缆索支承软管系统 (0) 投诉
P:2013-03-09 23:22:46
无法预览
cable sheathing material - 电缆护套材料 (0) 投诉
P:2013-04-11 16:47:44
谁下载了  可以贴出来
balloon - 鱼泡(同轴对绝缘的) (0) 投诉
