首页 > 标准共享
[国外标准] IEC 62230:2006 Electric cables Spark-test method
P:2013-01-14 23:09:43
应助:
http://www.dxdlw.com/ShowPost.asp?ThreadID=118228
标 准 号:IEC 62230:2006
英文名称:Electric cables - Spark-test method
正文语种:英法双语
标准摘要:The spark-test method specified in this standard is intended for the detection of defects in the insulation or sheathing layers of electric cables. For single core cables with no outer metallic layer, the general process is accepted as being equivalent to subjecting samples of those cables to a voltage test in water. This standard specifies the operational requirements for the spark-test equipment, as well as the principal characteristics, functional parameters and calibration procedures for each type of test equipment.
正文页数:46页
附件大小:13.08MB
fault detector - 故障探测器 (0) 投诉
