首页 > 汽车线缆
[汽车电线] 开发汽车-绞合压缩铜导线
P:2013-01-12 17:34:11
开发汽车-绞合压缩铜导线相关工艺交流
hydraulic unit - 液压装置 (0) 投诉
P:2013-01-12 17:35:19
2014年日系汽车要求.
nonintegral jacket - 非组合包套(光纤的) (0) 投诉
P:2013-01-13 08:23:51
把你的要求发上来看看
refrigerator - 致冷器 (0) 投诉
P:2013-01-30 15:11:18
AVSS Structure Parameter
<DIV align=center>Nominal Cross Section mm2</DIV><DIV align=center>Conductor</DIV><DIV align=center>Insulation Thickness </DIV><DIV align=center>Wire Outside Diameter </DIV><DIV align=center>Resistance at 20°C mΩ/m</DIV>
<DIV align=center>Conductor structure No.of Single Wires mm </DIV><DIV align=center>Nominal Cross Section mm2 </DIV><DIV align=center>approx.Outside Diameter mm </DIV><DIV align=center>Nominal mm </DIV><DIV align=center>Min.mm</DIV><DIV align=center>Nominal mm </DIV><DIV align=center>Max.mm</DIV>
<DIV align=center>0.3</DIV><DIV align=center>7/0.26</DIV><DIV align=center>0.3716</DIV><DIV align=center>0.8</DIV><DIV align=center>0.30</DIV><DIV align=center>0.24</DIV><DIV align=center>1.4</DIV><DIV align=center>1.5</DIV><DIV align=center>50.2</DIV>
<DIV align=center>7 bars pressed </DIV><DIV align=center>0.3716</DIV><DIV align=center>0.7</DIV><DIV align=center>0.35</DIV><DIV align=center>0.28</DIV><DIV align=center>1.4</DIV><DIV align=center>1.5</DIV><DIV align=center>50.2</DIV>
<DIV align=center>0.5</DIV><DIV align=center>7/0.32</DIV><DIV align=center>0.5629</DIV><DIV align=center>1.0</DIV><DIV align=center>0.30</DIV><DIV align=center>0.24</DIV><DIV align=center>1.6</DIV><DIV align=center>1.7</DIV><DIV align=center>32.7</DIV>
<DIV align=center>7 bars pressed </DIV><DIV align=center>0.5629</DIV><DIV align=center>0.9</DIV><DIV align=center>0.35</DIV><DIV align=center>0.28</DIV><DIV align=center>1.6</DIV><DIV align=center>1.7</DIV><DIV align=center>32.7</DIV>
<DIV align=center>0.85</DIV><DIV align=center>19/0.24</DIV><DIV align=center>0.8596</DIV><DIV align=center>1.2</DIV><DIV align=center>0.30</DIV><DIV align=center>0.24</DIV><DIV align=center>1.8</DIV><DIV align=center>1.9</DIV><DIV align=center>21.7</DIV>
<DIV align=center>7/0.40</DIV><DIV align=center>0.8796</DIV><DIV align=center>1.1</DIV><DIV align=center>0.30</DIV><DIV align=center>0.24</DIV><DIV align=center>1.8</DIV><DIV align=center>1.9</DIV><DIV align=center>20.8</DIV>
<DIV align=center>7 bars pressed</DIV><DIV align=center>0.8796</DIV><DIV align=center>1.1</DIV><DIV align=center>0.35</DIV><DIV align=center>0.28</DIV><DIV align=center>1.8</DIV><DIV align=center>1.9</DIV><DIV align=center>20.8</DIV>
<DIV align=center>11 bars pressed</DIV><DIV align=center>0.8846</DIV><DIV align=center>1.1</DIV><DIV align=center>0.35</DIV><DIV align=center>0.28</DIV><DIV align=center>1.8</DIV><DIV align=center>1.9</DIV><DIV align=center>20.8</DIV>
<DIV align=center>1.25</DIV><DIV align=center>19/0.29</DIV><DIV align=center>1.2550</DIV><DIV align=center>1.5</DIV><DIV align=center>0.30</DIV><DIV align=center>0.24</DIV><DIV align=center>2.1</DIV><DIV align=center>2.2</DIV><DIV align=center>14.9</DIV>
<DIV align=center>16 bars pressed</DIV><DIV align=center>1.2870</DIV><DIV align=center>1.4</DIV><DIV align=center>0.35</DIV><DIV align=center>0.28</DIV><DIV align=center>2.1</DIV><DIV align=center>2.2</DIV><DIV align=center>14.3</DIV>
<DIV align=center>2</DIV><DIV align=center>19/0.37</DIV><DIV align=center>2.0430</DIV><DIV align=center>1.9</DIV><DIV align=center>0.40</DIV><DIV align=center>0.32</DIV><DIV align=center>2.7</DIV><DIV align=center>2.8</DIV><DIV align=center>9.0</DIV>
<DIV align=center>0.3f</DIV><DIV align=center>19/0.16</DIV><DIV align=center>0.3821</DIV><DIV align=center>0.8</DIV><DIV align=center>0.30</DIV><DIV align=center>0.24</DIV><DIV align=center>1.4</DIV><DIV align=center>1.5</DIV><DIV align=center>48.8</DIV>
<DIV align=center>0.5f</DIV><DIV align=center>19/0.19</DIV><DIV align=center>0.5387</DIV><DIV align=center>1.0</DIV><DIV align=center>0.30</DIV><DIV align=center>0.24</DIV><DIV align=center>1.6</DIV><DIV align=center>1.7</DIV><DIV align=center>34.6</DIV>
<DIV align=center>0.75f</DIV><DIV align=center>19/0.23</DIV><DIV align=center>0.7895</DIV><DIV align=center>1.2</DIV><DIV align=center>0.30</DIV><DIV align=center>0.24</DIV><DIV align=center>1.8</DIV><DIV align=center>1.9</DIV><DIV align=center>23.6</DIV>
<DIV align=center>1.25f</DIV><DIV align=center>37/0.21</DIV><DIV align=center>1.2820</DIV><DIV align=center>1.5</DIV><DIV align=center>0.30</DIV><DIV align=center>0.24</DIV><DIV align=center>2.1</DIV><DIV align=center>2.2</DIV><DIV align=center>14.6</DIV>
<DIV align=center>2f</DIV><DIV align=center>37/0.26</DIV><DIV align=center>1.9640</DIV><DIV align=center>1.8</DIV><DIV align=center>0.40</DIV><DIV align=center>0.32</DIV><DIV align=center>2.6</DIV><DIV align=center>2.7</DIV><DIV align=center>9.50</DIV>
mandrel holder - 模芯座 (0) 投诉
P:2013-01-31 06:36:34
我们公司这里已经和日本古河技术合作在开发,有部分规格能量产了
type test - 型式试验 T (0) 投诉
P:2013-01-31 09:54:34
贵公司已经和古河技术合作在开发,有部分规格能量产了. .
我们正试 1, 多头硬导体.
                    2,多头软导体.
                   3, 双放线系统.
waterconductivity - 水导电率,水导电性,水传导率,水传导性 (0) 投诉
P:2013-01-31 19:29:31
都是电线厂自己做,你开发了卖给谁啊?
cable end cap - 电缆端帽,电缆终端 (0) 投诉
P:2013-02-01 11:42:16
都是电线厂自己做,你开发了卖给谁???
我们 三丰机电 一向研发工艺/设备共同努力的.
Bill of Material - 材料表 (0) 投诉
P:2013-02-02 14:30:01
有图片吗?
QLTY - quality质量,品质 (0) 投诉
P:2013-02-02 15:36:22
我们在生产!
expanded polythene - 多孔聚乙烯,泡沫聚乙烯 (0) 投诉
P:2013-02-04 20:27:41
欢迎春节后,到本司试机现场指导.
glass transition temperature - 玻璃化温度 (0) 投诉
P:2013-02-26 13:25:31
正试 1, 多头硬导体 11芯(压缩). 不好玩呢, 非正规组合,有难度.
     2 ,多头软导体,稍比较有样子.
     3, 双放线系统.有效.
duplicate lapping head - 双绕包头 (0) 投诉
P:2013-03-11 18:15:26
各位最好能上一下图片<div>
</div>
slip - 滑动,滑差<指拉线鼓轮圆周速度与线速度之间的差数> (0) 投诉
P:2013-03-30 15:16:11
我们 三丰机电 一向研发工艺/设备共同努力的,<div> 11芯(压缩). 不好玩呢, 有难度, </div><div>软态铜绞合 1.0mm 外径, 己试做成功了.</div>
fiat - 命令, 法令, 许可, 批准 (0) 投诉
P:2013-06-06 10:25:46
lay length - 节距;捻距 (0) 投诉
18
