首页 > 国外线缆
[技术资料] UL 2468#24线材规格 标准OD是多少?
P:2012-12-12 17:28:31
谢谢。求大神帮忙,最好能提供一个权威性的网站给我查找相关资料。
rebar - reinforcing bar (0) 投诉
P:2012-12-13 08:59:40
APPLIANCE WIRING MATERIAL
Subj.758Section 2Page 2468Issued:1968-05-07
Revised:2011-08-15
Style 2468Flat ribbon cable
Rating80 deg C, 300 Vac, Horizontal flame. Optional - 60 deg C or 80 deg C Oil.
Conductor32 AWG - 16 AWG, solid or stranded.
InsulationExtruded PVC, 15 mils minimum average thickness, 13 mils minimum thickness at any point.
AssemblyTwo to one hundred and fifty conductors laid parallel and in one plane. Same or mixed AWG. Minimum average and minimum at any point of insulation thickness after ripping shall be 15 mils and 13 mils, respectively. This forms a flat cable with a single row of conductors having a 1/2 in. maximum width web between insulated conductors.
ShieldOptional.
CoveringOptional, extruded PVC, 5 mils minimum thickness at any point, 80 mils maximum thickness.
StandardAppliance Wiring Material UL 758.
MarkingGeneral.
UseInternal wiring of Appliances.
UL and the UL Logo are trademarks of UL LLC © 2012
hamess - 编织袋 (0) 投诉
P:2012-12-13 10:52:57
多少P的?多少间距的?
如果是2P的话,1.5 X 3.0
coloured-stripe tracer - 着色标志带 (0) 投诉
