首页 > 架空线 裸电线
[金属复合线] 铜包铝的比重是多少? 铜包铝的代号是多少?
P:2007-08-31 15:30:33
铜包铝: CCA 按铜层体积比分为10%级和15%级。
CCA-10% 密度为 3.32 最小相对导电率63%
CCA-15% 密度为 3.63 最小相对导电率65%
铜包铝镁合金:CCAM
CCAM-15% 密度为 3.36 最小相对导电率65%
铜包钢: CCS 按导电率分为21%IACS级,30%IACS和40%IACS。
CCS-21%IACS 密度为 7.99
CCS-30%IACS 密度为 8.02
CCS-40%IACS 密度为 8.15
江南狼 奖励 0 金币,.1 声望,于 2007-9-1 8:13:10
PVCHR - heat-resisting polyvinyl chloride耐热聚氯乙烯 (0) 投诉
P:2008-02-29 14:24:55
| <DIV style="TEXT-ALIGN: center; mso-char-wrap: 1; mso-kinsoku-overflow: 1; mso-vertical-align-special: middle">规格</DIV> | <DIV style="TEXT-ALIGN: center; mso-char-wrap: 1; mso-kinsoku-overflow: 1; mso-vertical-align-special: middle">15A</DIV> | <DIV style="TEXT-ALIGN: center; mso-char-wrap: 1; mso-kinsoku-overflow: 1; mso-vertical-align-special: middle">15H</DIV> | |
| <DIV style="TEXT-ALIGN: center; mso-char-wrap: 1; mso-kinsoku-overflow: 1; mso-vertical-align-special: middle">抗拉强度(Mpa)</DIV> | <DIV style="TEXT-ALIGN: center; mso-char-wrap: 1; mso-kinsoku-overflow: 1; mso-vertical-align-special: middle">CCAM</DIV> | <DIV style="TEXT-ALIGN: center; mso-char-wrap: 1; mso-kinsoku-overflow: 1; mso-vertical-align-special: middle">≥220</DIV> | <DIV style="TEXT-ALIGN: center; mso-char-wrap: 1; mso-kinsoku-overflow: 1; mso-vertical-align-special: middle">>251</DIV> |
| <DIV style="TEXT-ALIGN: center; mso-char-wrap: 1; mso-kinsoku-overflow: 1; mso-vertical-align-special: middle">伸长率(%)</DIV> | <DIV style="TEXT-ALIGN: center; mso-char-wrap: 1; mso-kinsoku-overflow: 1; mso-vertical-align-special: middle">CCAM</DIV> | <DIV style="TEXT-ALIGN: center; mso-char-wrap: 1; mso-kinsoku-overflow: 1; mso-vertical-align-special: middle">≥15</DIV> | <DIV style="TEXT-ALIGN: center; mso-char-wrap: 1; mso-kinsoku-overflow: 1; mso-vertical-align-special: middle">≥1.0</DIV> |
| <DIV style="TEXT-ALIGN: center; mso-char-wrap: 1; mso-kinsoku-overflow: 1; mso-vertical-align-special: middle">电阻率(20℃Ω.mm2/m)</DIV> | <DIV style="TEXT-ALIGN: center; mso-char-wrap: 1; mso-kinsoku-overflow: 1; mso-vertical-align-special: middle">CCAM</DIV> | <DIV style="TEXT-ALIGN: center; mso-char-wrap: 1; mso-kinsoku-overflow: 1; mso-vertical-align-special: middle"><0.02857</DIV> | <DIV style="TEXT-ALIGN: center; mso-char-wrap: 1; mso-kinsoku-overflow: 1; mso-vertical-align-special: middle"><0.02857</DIV> |
| <DIV style="TEXT-ALIGN: center; mso-char-wrap: 1; mso-kinsoku-overflow: 1; mso-vertical-align-special: middle">密度(g/cm3)</DIV> | <DIV style="TEXT-ALIGN: center; mso-char-wrap: 1; mso-kinsoku-overflow: 1; mso-vertical-align-special: middle">CCAM</DIV> | <DIV style="TEXT-ALIGN: center; mso-char-wrap: 1; mso-kinsoku-overflow: 1; mso-vertical-align-special: middle">3.61</DIV> | <DIV style="TEXT-ALIGN: center; mso-char-wrap: 1; mso-kinsoku-overflow: 1; mso-vertical-align-special: middle">3.61</DIV> |
| <DIV style="TEXT-ALIGN: center; mso-char-wrap: 1; mso-kinsoku-overflow: 1; mso-vertical-align-special: middle">铜层体积比(%)</DIV> | <DIV style="TEXT-ALIGN: center; mso-char-wrap: 1; mso-kinsoku-overflow: 1; mso-vertical-align-special: middle">CCAM</DIV> | <DIV style="TEXT-ALIGN: center; mso-char-wrap: 1; mso-kinsoku-overflow: 1; mso-vertical-align-special: middle">13-17%</DIV> | <DIV style="TEXT-ALIGN: center; mso-char-wrap: 1; mso-kinsoku-overflow: 1; mso-vertical-align-special: middle">13-17%</DIV> |
voltage life characteristic - 电压寿命特性 (0) 投诉
48
