[问题求助] Dielectric PEE/PH 什么意思?
P:2012-11-06 11:03:05
菜鸟请教:
Dielectric PEE/PH 是什么意思?
跟通常的FPE有什么区别?
mil-foot - 密耳-英尺(电阻单位,指长度为1英尺,直径为1密耳的导线的电阻) (0) 投诉
P:2012-11-06 14:51:35
PEE / PH or gas injected is a new method to make a dielectric. Unicavi has been the first italian manufacturer to adopt and develop this new extrusion method that is also called PHYSICAL PROCESS. The most important difference between this new method and the traditional one called chemical (PEE) regards the different extrusion process. The PEE process use a chemical additive whereas the PHYSICAL process uses an inert gas ( Nitrogen). By using the traditional method we get a dielectric provided with a low meccanic robustness and a with a limited time stabilily of the electrical characteristics.
impedance matching - 阻抗匹配 (0) 投诉
P:2012-11-06 14:52:16
PEE /是指化学发泡,PH是指物理发泡。
HTA - high temperature alloy高温合金 (0) 投诉
P:2012-11-06 16:34:49
学习了
pliable armour steel strand - 柔软铠装绞合钢丝 (0) 投诉
P:2012-11-06 16:42:00
拜谢。。。。
test - 试验,检验,测试 (0) 投诉
P:2012-11-06 19:45:14
原来如此,还以为多深奥呢
balloon spring single ended cheeseholder - “鱼泡弹簧”单端纱锭座 (0) 投诉
P:2013-07-01 12:06:42
看了说明就知道怎么回事了。学习了。
老外就喜欢搞这套。
communication ball - 通信频带 (0) 投诉
