首页 > 特种电缆
[氟塑料缆] UL 1354 铁氟龙电线請教
P:2007-06-23 17:15:19
UNDERWRITERS LABORATORIES INC. APPLIANCE WIRING MATERIAL
Subject 758 Section 1 Page 1354 Issued: Feb. 19, 1964
Revised: Aug. 18, 1998
| Style 1354 | Coaxial Cable. |
| Rating | 60°C or 80°C, 30 V. |
| Conductors | No. 44 AWG min, material not specified. |
| Insulation | 2 mils min at any point, 125 mils max, Solid or Cellular PE, FRPE, Polypropylene, PFA, FEP, ECTFE, PTFE, ETFE or combination thereof with or without irradiation. The insulation may be tape wrapped solid or cellular PTFE applied directly over the conductor or applied as a spiral wrapped Polyethylene thread (5 mils min, 40 mils max) and enclosed with “tubed on” insulation. |
| Covering | Optional - Extruded PVC Polyethylene or Irradiated Polyethylene, or PFA, or Polyester film. Thicknesses not specified. |
| Shield | Page 24, required if outer shield is not provided. |
| Covering | Optional - Extruded PVC, or PFA, or heat sealed PVC tape, Polyamide Polyester, Kynar, FEP or PTFE, ECTFE, Tefzel, or lacquered braids, or tape wrapped PTFE Polyester film or Polyester-Polyethylene laminated film. Thicknesses not specified. |
| Outer Shield | Page 24, (optional if inner shield is provided). |
* | Outer Covering | Optional (required if outer shield is provided) - Extruded PVC, or PFA, or heat sealed PVC tape, Polyamide, Polyester, Kynar, FEP, PTFE, ECTFE, Tefzel, irradiated PE, irradiated PVC Polyurethane, or lacquered braid, thicknesses not specified. |
| Standard | UL 1581, Reference Standard for Electrical Wires Cables, and Flexible Cords. |
(Continued on Page 1354A)
Subject 758 Section 1 Page 1354A Issued: Feb. 19, 1964
Revised: April 24, 1992
| Instructions to UL Representative | Detailed examination. |
| UL Counter-Check Program | (4) Detailed Examination. (4) Horizontal Flame Test - Page 31. |
| Marking | General, Page 13. |
| Use | Internal wiring of Class 2 Circuits of Electronic Equipment or as insulated single in jacketed multiconductor cables. |
stress - 应力;电场强度 (0) 投诉
