[问题求助] IEC 61156-5 为什么找不到NEXT标准公式?
P:2012-10-29 15:01:43
如题,只有功率合公式,没有找到NEXT公式,请问哪里有?
light-duty cable - 轻型电缆,轻载电缆 (0) 投诉
P:2012-10-29 15:33:04
IEC 61156-1有,NEXT=10LOG10(P1N/P2N),知道公式,也没有太多实际作用
SZ-machine - SZ绞制机 (0) 投诉
P:2012-10-31 09:06:06
原文如下:
The worst pair power sum near-end crosstalk, PS NEXT, at all frequencies, f, in the frequency range indicated inTable 6 shall not be less than the value abtained from Equation (6) useing
                 PS NEXT(f)=PS NEXT(1)-15*log10(f)     (6)
For those frequencies where the calculated value of  PS NEXT is greater than 75 dB,the requirement shall be 75 dB.
The minimum pair-to-pair NEXT for any pair combination shall be at least 3 dB better than the PS NEXT for any pair.
measuring line for medical purposes - 医用测量线路 (0) 投诉
