[技术资料] 富士通 Infiniband 测试规范----请参考
P:2007-06-19 18:55:59
Testing Conditions:According to applicant’s specifications.
(1) Characteristic impedance :
: Use 50ohm termination
: Measurement area ; Two areas (Connector area , Cable ares)
: Measurement point ; Two point (maximum value and minimum value)
in a pair.
: Input signal ; Rise time 100ps (10~90%)(through the 3inches test pattern)
: Measurement axis ; horizontal, 200ps/div(connector) 2ns/div(cable at
length)vertical, 100mρ/div
(2) Reverse cross-talk :
: Use 50ohm termination (rive pair ,Victim pair)
: Measurement point ; 4 pairs/total crosstalk
: Input signal ; Rise time 100ps(10~90%)(through the 3inches test pattern)
: Measurement axis ; horizontal 500ps/div vertical 10mV/div
(3) Propagation delay and skew
: Measurement signal ; Through signal.(Not reflection signal)
: Measurement ; Within pair skew and between pairs skew.
: Measurement axis ; horizonal, 2ns/div(Prop delay) 500ps/div(within pairs
skew) vertical 100mV/div
(4) Eye pattern
: Input signal : 1Vpp(div). PRBS 2^23-
: Waveform ; ([signal+]-[signal-]) The waveform does not overflow the
screen.
: Measurement point(Eye eight); Center in the eye width
Measurement axis ; horizontal, 50ps/div vertical 200mV/div
(5) Insertion loss
: Method ; Use 6inches test pattern for calibration line
:The value ; Calculated by measurement line and calibration line.
: Measurement axis ; horizontal ; 100MHz~6000MHz
Pyralin - 皮勒林<一聚酰亚胺绝缘涂膜商品名> (0) 投诉
