首页 > 国外线缆
[问题求助] 陶瓷化硅橡胶绝缘电线
P:2012-10-07 11:41:36
亲爱的各位高手们,一外国客户要陶瓷化硅橡胶绝缘电线,要求如下,需求量很大 有哪家高手工厂可以做的,欢迎联系我
QQ757440116 ,请加备注"陶瓷化硅橡胶" 谢谢啦
Cable conductor 1.00mmq
Conductor: 32x0.193 in bare copper (Class 5 of Standard IEC 60228)
Outer diameter of the conductor: 2,55 mm
Standard color: Red – Black
Insulation: ceramics silicone EI2 quality,
Cable conductor 1.50mmq
Conductor: 30x0.245 in bare copper (Class 5 of Standard IEC 60228)
Outer diameter do the conductor: 2,95 mm
measurement and control in line - 在线测量与控制 (0) 投诉
P:2012-10-18 08:56:41
www.--CITCABLE.COM ,这家也有生产
OVPO - outside vapor phase oxidation外部汽相氧化(法),管外汽相氧化(法) (0) 投诉
P:2013-09-06 15:19:04
凯莱东尼线缆 上海办事处 Tel: 86-21-62860356 18930597073 Fax: 86-21-52524616 Email: rose@caledonian-cables.com 上海市南京西路1168号中信泰富广场3501室 |
CMCR - continuous melting,casting and rolling连铸连轧 (0) 投诉
