首页 > 电气装备用线缆
[计算机线] 谁有耐高温的计算机电缆啊?
P:2012-09-17 13:28:30
Cable Type                  Total length
19x1.5 (HT)                 1500 Meter = 19 Pair x 1.5 mm, insulation type should resist up to 200 deg C
3x2.5 (HT)                   1500 Meter = 3 Pair x 2.5 mm, insulation type should resist up to 200 deg C
7x1.5(HT)                    3000 Meter = 7 Pair x 1.5mm, insulation type should resist up to 200 deg C
07-KX.1-05-EI (HT)      3000 Meter = Thermocouple cable type (K), insulation type should resist up to 200 deg C
07-IP-09-EI (HT)          6000 Meter = 14 Pair x 0.5 mm, insulation type should resist up to 200 deg C
大概是:
19对*1.5mm2 耐高温200℃   1500米
3对*2.5mm2  耐高温200℃   1500米
7对*1.5mm2  耐高温200℃   3000米
7对*0.5mm2(1*0.80mm)  耐高温200℃   3000米  热电偶K型
7对*0.88mm2 (7*0.40mm)   耐高温200℃   6000米
不知大家谁有?
[muyuetan 在 2012-9-17 13:36:00 编辑过]
VLF testing - 甚低频试验 (0) 投诉
P:2012-09-17 14:24:03
有。但一般贸易的不于理睬
generator - 发生器,振荡器;发电机 (0) 投诉
