首页 > 标准共享
[国外标准] IEC/TS 62100-2004 地面航行照明原电路用电缆
P:2012-06-13 23:08:14
标准号:IEC/TS 62100-2004
中文名称:地面航行照明原电路用电缆
英文名称:Cables for aeronautical ground lighting primary circuits
标准组织:【IEC】国际电工委员会标准
发布日期: 2004.11.24 实施日期:2004.11.24
标准摘要:
Gives the construction, dimensions and test requirements of screened or unscreened single core cable to be installed in the primary circuits of series systems for lighting and beaconing of airports. It does not apply to primary cables with connectors moulded to them. This specification does not consider special performance of cables in case of fire. If such special performance (flame propagation, smoke emission and acidity/corrosivity of fumes) is required, relevant International Standards not mentioned here should be applied. The cables can, additionally, be subjected to particular requirements not included in this specification, if requested by the customer. Any additional tests or modification of dimensions should be agreed between the manufacturer and the customer. This specification takes into account the particular conditions of primary circuits and, as far as possible, is in line with the specifications contained in IEC 60502-2.
high-strength low alloyed steel - 高强度低合金钢 (0) 投诉
P:2012-06-13 23:19:38
标准页数:60页
附件大小:9.66MB
