首页 > 专业英语|国际贸易
[翻译求助] 专家们来看看这客户要的是什么线啊?
P:2012-05-29 15:12:47
it is 3phaze 400V ... usual flow will be 15kw -- cca 40A.
It needs to be good protected for deep ground instalation.
we are a small start up building our first test PV plant. We are integrating components which will be tested on this prototype plant.
Can we build your cable in? We need to connect inverter ouput (400V 3phaze) into grid. Can you send as sample for this test?
Container with other sample is already known and will be loaded next week.
thermal endurance property - 耐热性 (0) 投诉
