[材料介绍] 耐氟隆产品性能
P:2012-05-29 10:11:24
耐氟隆FEP通用型树脂是四氟乙烯与六氟丙烯的共聚物,具有优良的热稳定性,突出的化学惰性、优良的电绝缘性、低摩擦系数,优异的耐大气老化性、良好的耐气体(蒸汽)渗透性和不燃性。能在
FEP 性能表2(specification)
物理性能(Physical Properties) | 单位(Unit) | FEP(M-1) | FEP(EW-1) | FEP(EW-2) | FEP(EW-3) | FEP(EW-4) | FEP(EW-5) | FEP(EW-6) |
相对密度(Specific Gravity) | g/cm3 | 2.1-2.17 | 2.1-2.17 | 2.1-2.17 | 2.1-2.17 | 2.1-2.17 | 2.1-2.17 | 2.1-2.17 |
熔点(Melting Point) | ℃ | 260±5 | 260±5 | 260±5 | 260±5 | 255±5 | 255±5 | 255 |
熔融指数(Melt Index) | g/10min | 0.8-2 | 2.1-4 | 4.1-8 | 8.1-12 | 12.1-20 | 20.1-27 | 27.1-35 |
机械性能(Mechanical Properties) | ||||||||
硬度(Hardness) | 59 | 58 | 58 | 58 | 58 | 58 | 57 | |
断裂拉伸强度 | Mpa | 27.0 | 25.0 | 21.0 | 21.0 | 18.0 | 18.0 | 18.0 |
断裂伸长率(Tensile Strength at Break) | %(1/1) | ≥320 | ≥300 | ≥300 | ≥300 | ≥280 | ≥280 | ≥280 |
抗弯模量(Flexural Modulus) | Mp | 570 | 560 | 560 | 560 | 560 | 560 | 560 |
介电常数(Dielectric Constant) | <2.15 | <2.15 | <2.15 | <2.15 | <2.15 | <2.15 | <2.15 | |
损耗因子(Dissipation Factor) | <0.0007 | <0.0007 | <0.0007 | <0.0007 | <0.0007 | <0.0009 | <0.0009 | |
最低氧指数(Minimum Oxygen Index) | % | >95 | >95 | >95 | >95 | >95 | >95 | >95 |
玻璃态转化温度(Thermal Glass Transition) | ℃ | 66 | 66 | 66 | 66 | 66 | 66 | 66 |
corrugating unit - 轧纹装置 (0) 投诉
