[HDMI] HDMI的串音是如何产生的?
P:2007-06-01 10:18:50
HDMI传输高频信号过程中的远端串音是怎样产生的?多谢指点!!
damp proofing insulation - 防潮绝缘 (0) 投诉
P:2007-06-01 10:58:34
 <DIV class=O v:shape="_x0000_s1026"><DIV style="mso-line-spacing: '90 20 0'; mso-margin-left-alt: 216; mso-char-wrap: 1; mso-kinsoku-overflow: 1">•串音机理 </DIV><DIV style="mso-line-spacing: '90 20 0'; mso-margin-left-alt: 216; mso-char-wrap: 1; mso-kinsoku-overflow: 1">      因回路间存在电磁耦合,则第一回路的电磁波在回路周围产生电磁场,进而在第二回路产生干扰电流的现象称为串音 </DIV><DIV style="mso-line-spacing: '90 20 0'; mso-margin-left-alt: 216; mso-char-wrap: 1; mso-kinsoku-overflow: 1">•一次干扰参数 </DIV><DIV style="mso-line-spacing: '90 20 0'; mso-margin-left-alt: 216; mso-char-wrap: 1; mso-kinsoku-overflow: 1">    -电耦合 </DIV><DIV style="mso-line-spacing: '90 20 0'; mso-margin-left-alt: 216; mso-char-wrap: 1; mso-kinsoku-overflow: 1">     电耦合为被串电流与主串电压的比值.g---电耦合的有功分量(介质耦合),指主被串回路芯线间介质能量损耗不平衡的结果 </DIV><DIV style="mso-line-spacing: '90 20 0'; mso-margin-left-alt: 216; mso-char-wrap: 1; mso-kinsoku-overflow: 1">    -磁耦合 </DIV><DIV style="mso-line-spacing: '90 20 0'; mso-margin-left-alt: 216; mso-char-wrap: 1; mso-kinsoku-overflow: 1">     磁耦合为被串电压与主串电流的比值.r---磁耦合的有功分量(导电耦合),指主被串回路芯线间导体金属能量损耗不平衡的结果.m---电感耦合,指主被串回路部分电感不平衡的结果. </DIV><DIV style="mso-line-spacing: '90 20 0'; mso-margin-left-alt: 216; mso-char-wrap: 1; mso-kinsoku-overflow: 1">•二次传输参数 </DIV><DIV style="mso-line-spacing: '90 20 0'; mso-margin-left-alt: 216; mso-char-wrap: 1; mso-kinsoku-overflow: 1">     主要参数为近端串音衰减,远端串音衰减,远端串音防卫度 </DIV><DIV style="mso-line-spacing: '90 20 0'; mso-margin-left-alt: 216; mso-char-wrap: 1; mso-kinsoku-overflow: 1">     ---近端串音衰减 </DIV><DIV style="mso-line-spacing: '90 20 0'; mso-margin-left-alt: 216; mso-char-wrap: 1; mso-kinsoku-overflow: 1">         主串回路发送功率与串到被串回路近端功率的比值,取对数*10位,单位“Db” </DIV><DIV style="mso-line-spacing: '90 50 0'; mso-margin-left-alt: 216; mso-char-wrap: 1; mso-kinsoku-overflow: 1"> <DIV class=O v:shape="_x0000_s1026"><DIV style="mso-line-spacing: '100 20 0'; mso-margin-left-alt: 216; mso-char-wrap: 1; mso-kinsoku-overflow: 1">远端串音衰减 </DIV><DIV style="mso-line-spacing: '100 20 0'; mso-margin-left-alt: 216; mso-char-wrap: 1; mso-kinsoku-overflow: 1">    主串回路发送功率与串到被串回路远端功率的比值,取对数*10倍,单位“DB” </DIV><DIV style="mso-line-spacing: '100 20 0'; mso-margin-left-alt: 216; mso-char-wrap: 1; mso-kinsoku-overflow: 1">--衰减串音比(远端串音防卫度) </DIV><DIV style="mso-line-spacing: '100 20 0'; mso-margin-left-alt: 216; mso-char-wrap: 1; mso-kinsoku-overflow: 1">    被串回路远端收到的信号电平与串到该接收端的串音电平的有效期.当主串与被串回路相同时,可简化为远端串音衰减的差.(它直接影响信号的误码程度).串音的影响取决于接收的有功信号与串音功率的相对大小,因在远端信号经过衰减,信号相对较近端小,故通讯工程中串音防卫度是指远端串音防卫度. </DIV><DIV style="mso-line-spacing: '100 20 0'; mso-margin-left-alt: 216; mso-char-wrap: 1; mso-kinsoku-overflow: 1">•干扰参数的影响因素 </DIV><DIV style="mso-line-spacing: '100 20 0'; mso-margin-left-alt: 216; mso-char-wrap: 1; mso-kinsoku-overflow: 1">--数十KHZ以下的短电缆(制造长度)采用一次参数研究,高频或长电缆时回路间串音用一次参数很难确定,就用二次参数来衡量,一次干扰参数/二次干扰参数与回路间的相对位置及结构,通讯方式,结构上均匀性,及所用材料的质量回路长度信号的传输频率有关.</DIV></DIV></DIV></DIV>
ottolee 奖励 0 金币,.2 声望,于 2007-6-4 14:33:05
ODR - oscillation disk rheometer振动圆盘式流变仪 (0) 投诉
P:2007-06-01 14:32:32
谢谢!再请问:HDMI高频测试中的远端串音是如何测试的?
为什么从图形上看它的绝对值越大越好?
drawing coiler - 拉线成圈机 (0) 投诉
P:2007-06-01 15:10:52
The crosstalk of HDMI should be tested in time domain. The value should be as small as possible!
status monitoring system - 状态监控系统 (0) 投诉
P:2007-06-01 19:41:33
远端串音衰减掉的数值越大,剩余的产生的影响就小,所以衰减掉的数值越大越好,正负只代表相对量。
CAB - cellulose acetate butyrate丁酸-醋酸纤维 (0) 投诉
