首页 > 标准共享
[国外标准] DIN VDE 0282-15-2000 Rubber insulated cables of rated voltage up to and including 450/750 V – Part 15: Multicore cables insulated and sheathed with heat resistant silicone rubbe
P:2007-05-30 12:45:16
DIN VDE 0282-15-2000 Rubber insulated cables of rated voltage up to and including 450/750 V – Part 15: Multicore cables insulated and sheathed with heat resistant silicone rubbe.pdf
cable laid in parallel - 平行敷没的电缆 (0) 投诉
