[问题求助] 发泡工艺生产的芯线老化试验
P:2007-05-24 18:33:53
发泡工艺生产的芯线老化试验,还做抗张和断裂伸长?
Flame Test On Single Vertical Insulated Cables - 单根电缆垂直燃烧测试,单根电缆垂直燃烧试验 (0) 投诉
P:2007-05-26 16:00:27
UL758-2006新版好像规定在2008年5月1日后对AWM style1598, 1598等芯线需要作老化抗张及延伸等测试
但我也一直没有向UL索要到新版的正本
heat-shrink wrap - 热收缩绕包带 (0) 投诉
P:2007-05-26 16:35:26
目前來說,這方面UL標準還沒有正式的標準要求針對發泡材料
FGRP - fiber glass reinforced plastics玻璃纤维增强塑料 (0) 投诉
P:2007-05-26 17:22:28
更正:
UL AWM style 1598, 1589等
liquid crystal polymer - 液晶聚合物 (0) 投诉
P:2007-05-29 11:13:48
请仔细查询UL758—UL1581,如果没有这方面材料试验规定,那么可以说UL标准有漏洞,我们可以建议UL公司增加之
fuel heating system - 燃料加热系统 (0) 投诉
P:2007-06-06 10:27:00
学习中!
laser-welded metallic shield - 激光焊接金属屏蔽 (0) 投诉
P:2007-06-06 10:58:45
参见UL444:有规定发泡实验:
6.3.2.4 Specimens of PVDF rated 125°C, foamed, or multi-layered insulations 305 mm (13 in) long shall
be placed in a circulating-air oven conforming to ASTM Standards D 5423 (Type II ovens) and D 5374
and aged for the appropriate time and temperature shown in Table 9 for the insulation adjacent to the
conductor. When the insulation is foamed, the aging shall be as specified for the solid insulation. A
minimum of six specimens shall be tested. Insulations with band-marking inks may have the ink removed
before specimens are aged. After removal from the oven, the specimens shall rest for 16 – 96 h in still air
at room temperature and then be wound tightly, for six close turns, around a mandrel having a diameter
no greater than that of the insulated conductor under test. The insulation shall be examined for cracks
using a lens having magnification of 5X. The insulated conductor shall then be straightened, one side of
the tube of insulation sliced off with a knife or razor-blade, and the conductor removed for examination of
the inner surface of the insulation. There shall be no cracks on either the inside or the outside surface of
the insulation.
die changeover - 换模装置 (0) 投诉
