首页 > 标准共享
[国外标准] IEC 60332-1-1:2004 Tests on electric and optical fibre cables under fire conditio Part 1-1
P:2007-05-24 16:23:31
IEC 60332-1-1:2004 Tests on electric and optical fibre cables under fire conditions Part 1-1:Test for vertical flame propagation for a single insulated wire or cable Apparatus.pdf
ground-wire gradient - 架空地线的电位梯度 (0) 投诉
