[HDMI] HDMI 1.4 眼图与高频报告分析求教.
P:2012-04-18 11:30:43
| Parameter: | NA_Attenuation | Unit : dB/Cable | Result: | Pass | |||||||||||
| Start Freq | 10 | 825 | 2475 | 4125 | Pair | ||||||||||
| End Freq | 825 | 2475 | 4125 | 5100 | Status | ||||||||||
| Spec Max | -- | -- | -- | -- | ↓ | ||||||||||
| Pair 1 | -4.501 | -8.162 | -12.05 | -20.1 | Pass | ||||||||||
| Pair 2 | -4.663 | -8.215 | -13.38 | -18.4 | Pass | ||||||||||
| Spec Min | -5 | -12 | -20 | -25 | |||||||||||
| Worst Pair | Pair 2 | Pair 2 | Pair 2 | Pair 1 | |||||||||||
| Worst Freq | 809.68 | 2294.8 | 3805.3 | 4693.8 | |||||||||||
leakage conductor - 线路避雷器 (0) 投诉
P:2012-04-18 11:31:52
| Parameter: | TDR_CommonModeIMPZ | Unit : Ohm | Result: | Pass | |||||||||||
| Pair Name | Spec Max | Spec Min | Max Value | Min Value | Differ. | Average | Status | ||||||||
| Pair 1 | 40 | 25 | 32.36 | 26.57 | 5.79 | 29.465 | Pass | ||||||||
| Pair 2 | 40 | 25 | 33.89 | 27.88 | 6.01 | 30.885 | Pass | ||||||||
| Parameter: | TDR_DifferialIMPZ | Unit : Ohm | Result: | Fail | |||||||||||
| Pair 1 | 110 | 90 | 100.68 | 77.47 | 23.21 | 89.075 | Fail | ||||||||
| Pair 2 | 110 | 90 | 102.12 | 84.13 | 17.99 | 93.125 | Fail | ||||||||
nib - 尖端;模孔;突出部 (0) 投诉
P:2012-04-18 11:33:25
| Parameter: | TDR_ConnectorIMPZ | Unit : Ohm | Result: | Fail | |||||||||||
| Pair Name | Spec Max | Spec Min | Node 1 | Node 2 | Differ. | Average | Status | ||||||||
| Pair 1 | 115 | 85 | 101.14 | 77.41 | 23.73 | 89.275 | Fail | ||||||||
| Pair 2 | 115 | 85 | 100.5 | 84.05 | 16.45 | 92.275 | Fail | ||||||||
| Parameter: | TDR_FE_ConnectorIMPZ | Unit : Ohm | Result: | Fail | |||||||||||
| Pair 1 | 115 | 85 | 101.13 | 79.75 | 21.38 | 90.44 | Fail | ||||||||
| Pair 2 | 115 | 85 | 99.64 | 79.57 | 20.07 | 89.605 | Fail | ||||||||
| Parameter: | TDT_IntraPairSkew | Unit : ps | Result: | Pass | |||||||||||
| Pair Name | Spec Max | Spec Min | Skew Val. | Status | |||||||||||
| Pair 1 | 112 | -- | 23 | Pass | |||||||||||
| Pair 2 | 112 | -- | 28 | Pass | |||||||||||
presser - 加压器;压机工 (0) 投诉
P:2012-04-18 11:35:13
| Pair 1 | -4.563 | -8.336 | -12.46 | -19.42 | Pass | ||||||||||
| Pair 2 | -4.647 | -8.193 | -12.44 | -17.36 | Pass | ||||||||||
| Worst Pair | Pair 2 | Pair 1 | Pair 1 | Pair 1 | |||||||||||
| Worst Freq | 771.6 | 2307.5 | 3767.2 | 4719.2 | |||||||||||
cross-linking degree - 交联度 (0) 投诉
P:2012-04-18 11:37:36
| Parameter: | TDR_CommonModeIMPZ | Unit : Ohm | Result: | Fail | |||||||||||
| Pair 1 | 40 | 25 | 40.86 | 35.12 | 5.74 | 37.99 | Fail | ||||||||
| Pair 2 | 40 | 25 | 32.13 | 26.7 | 5.43 | 29.415 | Pass | ||||||||
| Pair 1 | 110 | 90 | 98.75 | 83.83 | 14.92 | 91.29 | Fail | ||||||||
| Pair 2 | 110 | 90 | 98.57 | 83.13 | 15.44 | 90.85 | Fail | ||||||||
| Pair 1 | 115 | 85 | 99.09 | 83.89 | 15.2 | 91.49 | Fail | ||||||||
| Pair 2 | 115 | 85 | 99 | 83.11 | 15.89 | 91.055 | Fail | ||||||||
stand-alone die polishing machine - 独立的线模抛光机 (0) 投诉
P:2012-04-18 11:39:07
| Pair 1 | 115 | 85 | 97.98 | 82.86 | 15.12 | 90.42 | Fail | ||||||||
| Pair 2 | 115 | 85 | 98.78 | 82.42 | 16.36 | 90.6 | Fail | ||||||||
| Pair 1 | 112 | -- | 35 | Pass | |||||||||||
| Pair 2 | 112 | -- | 20 | Pass | |||||||||||
duplex take-up stand - 双盘收线架 (0) 投诉
P:2012-04-18 11:40:34
all-plastic insulation - 全塑料绝缘 (0) 投诉
21
