首页 > 国外线缆
[问题求助] 谁能提供UL20674和UL2678两个安规
P:2012-04-18 10:36:18
谁能提供UL20674和UL2678两个安规,或者告诉这两者的区别,新人刚注册,没有金币,各位帮帮忙,谢谢
pickling tank - 酸洗槽 (0) 投诉
P:2012-04-18 10:51:44
UNDERWRITERS LABORATORIES INC.               APPLIANCE WIRING MATERIAL
Subject 758      Section 2       Page 2678        Issued:  Jan. 8, 1974
                                    Revised:  Jan. 26, 2001
Style 2678      Flat Cable.
______________________________________________________________________________
Rating      105蚓, 150 V.
Conductors      2 thru 150, 20-36 AWG solid or stranded copper, tinned
*           or untinned, laid parallel.
Insulation      Polyvinyl Chloride; 6 mils minimum at any point.
            Extruded or heat laminated PVC.  Sections of the
            cable may be split into single or groups of conductors.
*Shield     Optional.
Covering        PVC, 5 mils min at any point.
(Optional)
*Standard       Appliance Wiring Material UL 758.
Instructions    Detailed examination.
to UL          Dielectric Withstand 1500 Volts, 50 to 60 Hz for one
Representative     minute between conductors and water or Spark Test.
*            Flexing - Unaged.  Insulation shall
               not crack when flexed flatwise into a "U" bend around
               1/8 inch mandrel, ridged side out.
UL          (4)  Detailed Examination.
*Counter-Check  (4)  Physical Properties.
*Program        (4)  Deformation Test.
            (4)  Flexing - Age 7 days at 136°C then flexed as above.
*           (4)  Cold Bend, except condition on hour at -20                         then flex into a "U" bend around 1/8 inch mandrel.
            (2)  Horizontal Flame Test.
*Marking        General
Use         Internal Wiring of Electronic Equipment, such as
            computer and electric business machines.
Subject 758 Section 2 Page 20674 Issued: Feb. 15, 1991
Revised: March 26, 2001
Style 20674 Shielded Flat Cable.
Rating 105°C, 150 V or 300 V.
Conductors 2 through 150, Nos. 24-40 AWG, solid or stranded, laid
* parallel.
Insulation Thermoplastic elastomer, 6 mils min avg thickness. Top or
bottom layers may form ridges over conductors. See Facing
Page for compound.
*Shield Optional.
Covering (Optional) - PVC, TPE, or Polyolefin, 4 mils min at any
point, 80 mils max.
to UL Dielectric strength 1500 V for wire rated 300 V
Representative 1250 V for wire rated 150 V, 60 Hz for 1 min
between conductors and water (immersed 1 h) or
* Spark Test. Flexing flatwise into a U-bend around
1/16 in dia mandrel, ridged side out.
UL (4) Detailed examination.
Counter-Check (4) Physical properties of insulation unaged
Program and after 7 days at 136°C. See Facing Page.
(4) Flexing Test - 7 days at 136°C, then flexed as above.
(4) Cold Bend Test - 1/8 in dia mandrel, 1 h at -20°C.
* (2) Horizontal Flame Test.
*Marking General.
Use Internal Wiring of Electrical Equipment; such as Electronic
Computers and Electric Business Machines.
velocity - 速度 (0) 投诉
P:2012-04-18 12:45:15
Thank you very much!
PAP - polyethylene-aluminium-polyethylene聚乙烯-铝-聚乙烯综合护层<铝带内面复以聚乙烯、纵包后外面再挤包聚乙烯> (0) 投诉
P:2012-04-18 17:54:06
路过
看看
waterblocking - 阻水,挡水,堵水 (0) 投诉
P:2012-04-25 20:01:57
路过支持!
pig casting machine - 铸锭机 (0) 投诉
