[Thunderbolt] Thunderbolt 线材结构
P:2012-04-03 10:57:29
Thunderbolt 线材结构,OD4.5,四对高频芯线,中间NYLON填充
[active 在 2012-4-3 10:58:41 编辑过]
mill scale - 轧屑 (0) 投诉
P:2012-04-03 11:30:28
下载 。。。
loop resistance - 回路电阻,环路电阻 (0) 投诉
P:2012-04-19 11:03:32
下载!长长见识!
multiplex timing source - 复用定时信源 (0) 投诉
P:2012-04-26 18:58:13
长长见识长长见识
formation yard - 装配车间 (0) 投诉
P:2012-04-26 22:59:10
lapper for aluminium tape - 铝带绕包头 (0) 投诉
P:2012-05-04 14:25:48
這也拿來賣錢???
ram - 推锭机;活塞;压头<压力机的> (0) 投诉
P:2012-05-08 16:45:26
世道乱了呀,什么都拿来赚钱!我有免费的!
GA - general average平均值 (0) 投诉
P:2012-05-11 14:37:51
一个截面图而已,还有20金币,太会歉了吧
to float a cable ashore - 用浮筒把电缆拉上海岸(敷设) (0) 投诉
P:2012-05-11 16:06:57
想钱想疯了啊
current-carrying capacity - 载流量,负载能力。导体所能充许通过之最大电流值,由于电流所产生之热不致影响电缆安全之最大限度。 (0) 投诉
P:2012-05-12 08:48:04
最新资料就得投入点东西吧
broadband network termination - 宽带网络终端 (0) 投诉
P:2012-05-12 09:00:05
說的是,有CHIP的資料嗎?
single-twist buncher - 单倍束线机,单节距束线机 (0) 投诉
P:2012-05-12 09:41:42
CHIP的資料在网上搜索一下看有没有!
silver-jacketed wire - 镀银线 (0) 投诉
P:2012-05-12 09:47:09
New Thunderbolt chips, dubbed Cactus Ridge, coming in 2012
Thunderbolt is certainly taking its sweet time catching on, but Intel isn't about to give up yet. In 2012 the company will be rolling out Cactus Ridge, a replacement for it's current Light Ridge and Eagle Ridge solutions. There will be two versions: a quad Thunderbolt channel, dual DisplayPort model (replacing the similarly speced Light Ridge); and a dual T-bolt, single DisplayPort edition (taking over for Eagle Ridge). Exactly when they'll land next year or how much it'll cost OEMs to shoehorn the controllers into their machines is still a mystery, but we're holding out hope that this time next year the 10Gbps jacks will be in every Dell, Acer and Apple.
aluminium melter - 熔铝炉 (0) 投诉
P:2012-05-12 10:14:19
接点:
Pin out
Pin 1
GND
Ground
Pin 2
HPD
Hot Plug Detect
Pin 3
HS0TX(P)
HighSpeed Transmit 0 (positive)
Pin 4
HS0RX(P)
HighSpeed Receive 0 (positive)
Pin 5
HS0TX(N)
HighSpeed Transmit 0 (negative)
Pin 6
HS0RX(N)
HighSpeed Receive 0 (negative)
Pin 7
GND
Ground
Pin 8
GND
Ground
Pin 9
LSR2P TX
LowSpeed Transmit
Pin 10
GND
Ground (reserved)
Pin 11
LSP2R RX
LowSpeed Receive
Pin 12
GND
Ground (reserved)
Pin 13
GND
Ground
Pin 14
GND
Ground
Pin 15
HS1TX(P)
HighSpeed Transmit 1 (positive)
Pin 16
HS1RX(P)
HighSpeed Receive 1 (positive)
Pin 17
HS1TX(N)
HighSpeed Transmit 1 (negative)
Pin 18
HS1RX(N)
HighSpeed Receive 1 (negative)
Pin 19
GND
Ground
Pin 20
DPPWR
Power
This is the pinout for both sides of the connector, source side and sink side. The cable is actually a crossover cable, it swaps all receive and transmit lanes, e.g. HS1TX(P) of the source is connected to HS1RX(P) of the sink.
tubularbloc cage strander - 筒笼式绞线机,管笼式绞线机 (0) 投诉
P:2012-05-22 23:06:21
感谢!大公无私~
rubber coated textile tape - 橡皮带,胶布带 (0) 投诉
35
