首页 > 标准共享
[国外标准] UL 3226-2000 活页
P:2007-05-21 08:42:32
UL3226那位大虾有?给小弟发一份。多谢
OFLAN - optical fiber local area network光纤局域网 (0) 投诉
P:2007-05-21 08:48:44
网上自己查啊
locator - 探测器,定位器 (0) 投诉
P:2007-05-21 08:54:05
没找到,烦请指导
wire type high speed sizing polishing unit - 线型高速整形-抛光装置(线模用) (0) 投诉
P:2007-05-21 16:46:14
UNDERWRITERS LABORATORIES INC.                APPLIANCE WIRING MATERIAL
Subj. 758      Section 3      Page 3226           Issued:  Oct. 5, 1967
                                 Revised:  Nov. 8, 2000
Style 3226    Heat-Resistant Cross-Linked Polyethylene-Insulation Wire.
______________________________________________________________________________
Rating     125°C dry, 75°C Moisture Resistant; 600 V.
Conductor     No. 26-9 AWG; Inclusive, tinned, or untinned solid or
*          stranded copper.  Splices same as required for
           rubber-insulated wire.
Insulation    45 mil min average, 40 mil min at any point, chemically
           cross-linked thermosetting polyethylene, see Facing Page for
           compound identification.
*Standard     Appliance Wiring Material UL 758.
Instructions  Detailed Examination.
to UL                Tensile Strength and Elongation of Representative.
Representative    Insulation, see Facing Page.
*          Spark Test, 6000 V.
           (12)  Insulation Resistance, same as Type RHW.
UL         (4)  Detailed Examination.
Counter-Check (4)  Tensile Strength and Elongation, see Facing Page.
*Program      (4)  Heat Shock.  (at 150°C).
*          (4)  Deformation. (at 121°C, T2 to T1 = 0.60)
*          (4)  Cold Bend.
           (4)  Capacitance and Stability Factor Test at 75°C, same as
                Type XHHW.
           (4)  Mechanical Water Absorption at 82°C, same as
                Type XHHW.
*Marking      General.
Use        Internal Wiring of Appliances where exposed to temperatures
           not exceeding 125°C dry, 75°C Moisture Resistant.
wire industry yearbook - 线缆工业年鉴 (0) 投诉
P:2007-05-28 11:06:17
多谢4楼的朋友
MM - multi-mode多模 (0) 投诉
