架空绝缘导线参数
标准JKLGYJ结构尺寸表及参数、交联聚氯乙烯 | |||||||||||||||
序号 | 型号规格 | 导体结构n/mm | 导体外径mm | 内屏蔽厚度mm | 绝缘厚度mm | 电缆外径mm | 弯曲半径 | 电缆计算重量KG/KM | 单位长度(m/吨) | 绝缘体积电阻不小于MO.KM | 20℃时导体直流电阻≦o/km | 导体计算拉断力≧n | 浸水1小时耐压电压kv | 允许载流量A | |
敷设 | 运行 | ||||||||||||||
1 | JKLYJ-10 | 7/1.37 | 3.80 | 0.70 | 3.40 | 12.00 | 240 | 264 | 77.5 | 12903.2 | 1500 | 3.080 | - | 18 | 56 |
2 | JKLYJ-16 | 7/1.75 | 4.80 | 0.70 | 3.40 | 13.00 | 260 | 286 | 124.0 | 8064.5 | 1500 | 1.910 | - | 18 | 87 |
3 | JKLYJ-25 | 7/2.24 | 6.00 | 0.80 | 3.40 | 14.40 | 288 | 320 | 193.6 | 5165.3 | 1500 | 1.200 | 3762 | 18 | 118 |
4 | JKLYJ-35 | 7/2.57 | 7.00 | 0.80 | 3.40 | 15.40 | 308 | 340 | 233.2 | 4288.2 | 1500 | 0.868 | 5177 | 18 | 149 |
5 | JKLYJ-50 | 7/3.06 | 8.30 | 0.80 | 3.40 | 16.70 | 334 | 368 | 290.8 | 3438.8 | 1500 | 0.641 | 7011 | 18 | 180 |
6 | JKLYJ-70 | 14/2.57 | 10.00 | 0.80 | 3.40 | 18.40 | 368 | 405 | 365.7 | 2734.5 | 1500 | 0.443 | 10354 | 18 | 226 |
7 | JKLYJ-95 | 19/2.57 | 11.60 | 0.80 | 3.40 | 20.00 | 400 | 440 | 495.2 | 2019.4 | 1500 | 0.320 | 13727 | 18 | 276 |
8 | JKLYJ-120 | 36/2.21 | 13.00 | 0.80 | 3.40 | 21.40 | 428 | 471 | 543.6 | 1839.6 | 1500 | 0.253 | 17399 | 18 | 320 |
9 | JKLYJ-150 | 30/2.57 | 14.60 | 0.80 | 3.40 | 23.00 | 460 | 506 | 648.7 | 1541.5 | 1500 | 0.206 | 21033 | 18 | 366 |
10 | JKLYJ-185 | 37/2.57 | 16.20 | 0.80 | 3.40 | 24.60 | 492 | 541 | 761.9 | 1312.5 | 1500 | 0.164 | 26732 | 18 | 423 |
11 | JKLYJ-240 | 37/2.92 | 18.40 | 0.80 | 3.40 | 26.80 | 536 | 590 | 946.1 | 1057.0 | 1500 | 0.125 | 34679 | 18 | 503 |
12 | JKLYJ-300 | 61/2.57 | 20.60 | 0.80 | 3.40 | 29.00 | 580 | 638 | 1130.0 | 885.0 | 1500 | 0.100 | 43349 | 18 | 583 |
JKLYJ-Q结构尺寸表及参数、轻型聚氯乙烯 | |||||||||||||||
1 | JKLYJ/Q-10 | 7/1.37 | 3.80 | 0.00 | 2.50 | 8.80 | 176 | 194 | 26.8 | 37313.4 | 1000 | 1.830 | - | 12 | 56 |
2 | JKLYJ/Q-16 | 7/1.75 | 4.80 | 0.00 | 2.50 | 9.80 | 196 | 216 | 42.8 | 23364.5 | 1000 | 1.150 | - | 12 | 87 |
3 | JKLYJ/Q-25 | 7/2.24 | 6.00 | 0.00 | 2.50 | 11.00 | 220 | 242 | 66.9 | 14947.7 | 1000 | 1.200 | 3762 | 12 | 118 |
4 | JKLYJ/Q-35 | 7/2.57 | 7.00 | 0.00 | 2.50 | 12.00 | 240 | 264 | 93.5 | 10695.2 | 1000 | 0.868 | 5177 | 12 | 149 |
5 | JKLYJ/Q-50 | 7/3.06 | 8.30 | 0.00 | 2.50 | 13.30 | 266 | 293 | 133.6 | 7485.0 | 1000 | 0.641 | 7011 | 12 | 180 |
6 | JKLYJ/Q-70 | 14/2.57 | 10.00 | 0.00 | 2.50 | 15.00 | 300 | 330 | 187.8 | 5324.8 | 1000 | 0.443 | 10354 | 12 | 226 |
7 | 市场标准JKLYJ-95 | 19/2.57 | 11.60 | 0.00 | 2.50 | 16.60 | 332 | 365 | 255.5 | 3913.9 | 1000 | 0.320 | 13727 | 12 | 276 |
8 | 市场标准JKLYJ-120 | 36/2.21 | 13.00 | 0.00 | 2.50 | 18.00 | 360 | 396 | 323.3 | 3093.1 | 1000 | 0.253 | 17399 | 12 | 320 |
9 | JKLYJ/Q-150 | 30/2.57 | 14.60 | 0.00 | 2.50 | 19.60 | 392 | 431 | 406.5 | 2460.0 | 1000 | 0.206 | 21033 | 12 | 366 |
10 | JKLYJ/Q-185 | 37/2.57 | 16.20 | 0.00 | 2.50 | 21.20 | 424 | 466 | 500.8 | 1996.8 | 1000 | 0.164 | 26732 | 12 | 423 |
11 | JKLYJ/Q-240 | 37/2.92 | 18.40 | 0.00 | 2.50 | 23.40 | 468 | 515 | 655.9 | 1524.6 | 1000 | 0.125 | 34679 | 12 | 503 |
12 | JKLYJ/Q-300 | 61/2.57 | 20.60 | 0.00 | 2.50 | 25.60 | 512 | 563 | 815.6 | 1226.1 | 1000 | 0.100 | 43349 | 12 | 583 |
JKYJ结构尺寸表及参数 | |||||||||||||||
1 | JKYJ-10 | 7/1.37 | 3.80 | 0.70 | 3.40 | 12.00 | 240 | 264 | 219.2 | 4562.0 | 1500 | 1.830 | - | 18 | 72 |
2 | JKYJ-16 | 7/1.75 | 4.80 | 0.70 | 3.40 | 13.00 | 260 | 286 | 137.0 | 7299.3 | 1500 | 1.150 | - | 18 | 112 |
3 | JKYJ-25 | 7/2.24 | 6.00 | 0.80 | 3.40 | 14.40 | 288 | 320 | 342.5 | 2919.7 | 1500 | 0.749 | 8465 | 18 | 152 |
4 | JKYJ-35 | 7/2.57 | 7.00 | 0.80 | 3.40 | 15.40 | 308 | 340 | 440.2 | 2271.7 | 1500 | 0.540 | 11731 | 18 | 192 |
5 | JKYJ-50 | 7/3.06 | 8.30 | 0.80 | 3.40 | 16.70 | 334 | 368 | 587.2 | 1703.0 | 1500 | 0.399 | 16502 | 18 | 232 |
6 | JKYJ-70 | 14/2.57 | 10.00 | 0.80 | 3.40 | 18.40 | 368 | 405 | 787.2 | 1270.3 | 1500 | 0.276 | 23461 | 18 | 291 |
7 | JKYJ-95 | 19/2.57 | 11.60 | 0.80 | 3.40 | 20.00 | 400 | 440 | 1027.2 | 973.5 | 1500 | 0.199 | 31759 | 18 | 357 |
8 | JKYJ-120 | 36/2.21 | 13.00 | 0.80 | 3.40 | 21.40 | 428 | 471 | 1259.2 | 794.2 | 1500 | 0.158 | 39911 | 18 | 413 |
9 | JKYJ-150 | 30/2.57 | 14.60 | 0.80 | 3.40 | 23.00 | 460 | 506 | 1550.1 | 645.1 | 1500 | 0.128 | 49505 | 18 | 473 |
10 | JKYJ-185 | 37/2.57 | 16.20 | 0.80 | 3.40 | 24.60 | 492 | 541 | 1871.6 | 534.3 | 1500 | 0.1021 | 61846 | 18 | 545 |
11 | JKYJ-240 | 37/2.92 | 18.40 | 0.80 | 3.40 | 26.80 | 536 | 590 | 2399.1 | 416.8 | 1500 | 0.0777 | 79823 | 18 | 647 |
12 | JKYJ-300 | 61/2.57 | 20.60 | 0.80 | 3.40 | 29.00 | 580 | 638 | 2937.4 | 340.4 | 1500 | 0.619 | 99788 | 18 | 749 |
国标标准JKLGYJ结构尺寸表及参数、交联聚氯乙烯 | |||||||||||||||
1 | JKLGYJ-10/2 | 6/1.50+1/1.50 | 3.80 | 0.80 | 3.40 | 12.20 | 244 | 268 | 144.7 | 6910.9 | 1500 | 3.080 | 3700 | 18 | 56 |
2 | JKLGYJ-16/3 | 6/1.85+1/1.85 | 4.80 | 0.80 | 3.40 | 13.20 | 264 | 290 | 177.0 | 5649.7 | 1500 | 1.910 | 5517 | 18 | 87 |
3 | JKLGYJ-25/4 | 6/2.32+1/2.32 | 6.30 | 0.80 | 3.40 | 14.70 | 294 | 323 | 235.5 | 4246.3 | 1500 | 1.200 | 8360 | 18 | 118 |
4 | JKLGYJ-35/6 | 6/2.72+1/2.72 | 7.40 | 0.80 | 3.40 | 15.80 | 316 | 350 | 279.4 | 3579.1 | 1500 | 0.968 | 11990 | 18 | 149 |
5 | JKLGYJ-50/8 | 6/3.20+1/3.20 | 8.60 | 0.80 | 3.40 | 17.00 | 340 | 374 | 354.7 | 2819.3 | 1500 | 0.641 | 16320 | 18 | 180 |
6 | JKLGYJ-50/30 | 12/2.32+7/2.32 | 10.80 | 0.80 | 3.40 | 19.20 | 384 | 422 | 553.8 | 1805.7 | 1500 | 0.641 | 10500 | 18 | 180 |
7 | JKLGYJ-70/10 | 6/3.80+1/3.80 | 10.80 | 0.80 | 3.40 | 19.20 | 384 | 422 | 462.8 | 2160.8 | 1500 | 0.443 | 22220 | 18 | 226 |
8 | JKLGYJ-70/40 | 12/2.72+7/2.72 | 12.60 | 0.80 | 3.40 | 21.00 | 420 | 462 | 714.2 | 1400.2 | 1500 | 0.443 | 55390 | 18 | 226 |
9 | JKLGYJ-95/15 | 26/2.15+7/1.67 | 12.50 | 0.80 | 3.40 | 20.90 | 418 | 460 | 592.5 | 1687.8 | 1500 | 0.320 | 33250 | 18 | 276 |
10 | JKLGYJ-95/20 | 7/4.16+7/1.85 | 13.00 | 0.80 | 3.40 | 21.40 | 428 | 471 | 621.5 | 1609.0 | 1500 | 0.320 | 35340 | 18 | 276 |
11 | JKLGYJ-95/55 | 12/3.20+7/3.20 | 15.20 | 0.80 | 3.40 | 23.60 | 472 | 520 | 949.5 | 1053.2 | 1500 | 0.320 | 74200 | 18 | 276 |
12 | JKLGYJ-120/20 | 26/2.38+7/1.85 | 13.80 | 0.80 | 3.40 | 22.40 | 448 | 493 | 697.7 | 1433.3 | 1500 | 0.253 | 38950 | 18 | 320 |
13 | JKLGYJ-120/25 | 7/4.72+7/2.10 | 14.80 | 0.80 | 3.40 | 23.20 | 464 | 510 | 1164.1 | 859.0 | 1500 | 0.253 | 45480 | 18 | 320 |
14 | JKLGYJ-120/70 | 12/3.60+7/3.60 | 17.00 | 0.80 | 3.40 | 25.40 | 508 | 560 | 1162.1 | 860.5 | 1500 | 0.253 | 95450 | 18 | 320 |
15 | JKLGYJ-150/8 | 18/3.20+1/3.20 | 14.50 | 0.80 | 3.40 | 22.90 | 458 | 503 | 698.7 | 1431.2 | 1500 | 0.206 | 31220 | 18 | 366 |
16 | JKLGYJ-150/20 | 24/2.78+7/1.85 | 15.20 | 0.80 | 3.40 | 23.60 | 472 | 520 | 797.4 | 1254.1 | 1500 | 0.206 | 44300 | 18 | 366 |
17 | JKLGYJ-150/25 | 26/2.70+7/2.10 | 15.50 | 0.80 | 3.40 | 23.90 | 478 | 526 | 849.9 | 1176.6 | 1500 | 0.206 | 51400 | 18 | 366 |
18 | JKLGYJ-150/35 | 30/2.50+7/2.50 | 15.80 | 0.80 | 3.40 | 24.20 | 484 | 532 | 927.6 | 1078.1 | 1500 | 0.206 | 61770 | 18 | 366 |
19 | JKLGYJ-185/25 | 24/3.15+7/2.10 | 17.10 | 0.80 | 3.40 | 25.20 | 504 | 554 | 946.5 | 1056.5 | 1500 | 0.164 | 56450 | 18 | 423 |
20 | JKLGYJ-185/30 | 26/2.98+7/2.32 | 17.50 | 0.80 | 3.40 | 25.90 | 518 | 570 | 1013.3 | 986.9 | 1500 | 0.164 | 61100 | 18 | 423 |
21 | JKLGYJ-185/45 | 30/2.80+7/2.80 | 18.00 | 0.80 | 3.40 | 26.40 | 528 | 581 | 1130.8 | 884.3 | 1500 | 0.164 | 76180 | 18 | 423 |
22 | JKLGYJ-240/30 | 24/3.60+7/2.40 | 20.00 | 0.80 | 3.40 | 28.40 | 568 | 625 | 1234.4 | 810.1 | 1500 | 0.125 | 71840 | 18 | 503 |
23 | JKLGYJ-240/40 | 26/3.42+7/2.66 | 20.00 | 0.80 | 3.40 | 28.40 | 568 | 625 | 1280.7 | 780.8 | 1500 | 0.125 | 79200 | 18 | 503 |
24 | JKLGYJ-300/40 | 24/3.99+7/2.66 | 23.00 | 0.80 | 3.40 | 31.40 | 628 | 691 | 1459.1 | 685.4 | 1500 | 0.100 | 83000 | 18 | 583 |
JKLGYJ/Q结构尺寸表及参数、轻型聚氯乙烯 | |||||||||||||||
1 | JKLGYJ-10/2 | 6/1.50+1/1.50 | 3.80 | 0.00 | 2.50 | 8.80 | 196 | 216 | 89.4 | 11185.7 | 1000 | 3.080 | 3700 | 18 | 56 |
2 | JKLGYJ-16/3 | 6/1.85+1/1.85 | 4.80 | 0.00 | 2.50 | 9.80 | 196 | 216 | 120.8 | 8278.1 | 1000 | 1.910 | 5517 | 18 | 87 |
3 | JKLGYJ-25/4 | 6/2.32+1/2.32 | 6.30 | 0.00 | 2.50 | 11.30 | 226 | 250 | 166.2 | 6016.8 | 1000 | 1.200 | 8360 | 18 | 118 |
4 | JKLGYJ/Q-35/6 | 6/2.72+1/2.72 | 7.40 | 0.00 | 2.50 | 12.40 | 248 | 272.8 | 212.8 | 4699.2 | 1000 | 0.968 | 11990 | 12 | 149 |
5 | JKLGYJ/Q-50/8 | 6/3.20+1/3.20 | 8.60 | 0.00 | 2.50 | 13.60 | 272 | 299.2 | 283.0 | 3533.6 | 1000 | 0.641 | 16320 | 12 | 180 |
6 | JKLGYJ/Q-50/30 | 12/2.32+7/2.32 | 10.80 | 0.00 | 2.50 | 15.80 | 316 | 347.6 | 467.3 | 2140.0 | 1000 | 0.641 | 10500 | 12 | 180 |
7 | JKLGYJ/Q-70/10 | 6/3.80+1/3.80 | 10.80 | 0.00 | 2.50 | 15.80 | 316 | 347.6 | 381.8 | 2619.2 | 1000 | 0.443 | 22220 | 12 | 226 |
8 | JKLGYJ/Q-70/40 | 12/2.72+7/2.72 | 12.60 | 0.00 | 2.50 | 17.60 | 352 | 387.2 | 619.5 | 1614.2 | 1000 | 0.443 | 55390 | 12 | 226 |
9 | JKLGYJ-95/15 | 26/2.15+7/1.67 | 12.50 | 0.00 | 2.50 | 17.50 | 350 | 385 | 487.7 | 2050.4 | 1000 | 0.320 | 33250 | 12 | 276 |
10 | JKLGYJ/Q-95/20 | 7/4.16+7/1.85 | 13.00 | 0.00 | 2.50 | 18.00 | 360 | 396 | 523.3 | 1910.9 | 1000 | 0.320 | 35340 | 12 | 276 |
11 | JKLGYJ/Q-95/55 | 12/3.20+7/3.20 | 15.20 | 0.00 | 2.50 | 20.20 | 404 | 444.4 | 835.0 | 1197.6 | 1000 | 0.320 | 74200 | 12 | 276 |
12 | JKLGYJ/Q-120/20 | 26/2.38+7/1.85 | 13.80 | 0.00 | 2.50 | 18.80 | 376 | 413.6 | 586.0 | 1706.5 | 1000 | 0.253 | 38950 | 12 | 320 |
13 | JKLGYJ/Q-120/25 | 7/4.72+7/2.10 | 14.80 | 0.00 | 2.50 | 19.80 | 396 | 435.6 | 654.5 | 1527.9 | 1000 | 0.253 | 45480 | 12 | 320 |
14 | JKLGYJ/Q-120/70 | 12/3.60+7/3.60 | 17.00 | 0.00 | 2.50 | 22.00 | 440 | 484 | 1039.3 | 962.2 | 1000 | 0.253 | 95450 | 12 | 320 |
15 | JKLGYJ/Q-150/8 | 18/3.20+1/3.20 | 14.50 | 0.00 | 2.50 | 19.50 | 390 | 429 | 588.0 | 1700.7 | 1000 | 0.206 | 31220 | 12 | 366 |
16 | JKLGYJ/Q-150/20 | 24/2.78+7/1.85 | 15.20 | 0.00 | 2.50 | 20.20 | 404 | 444.4 | 679.0 | 1472.8 | 1000 | 0.206 | 44300 | 12 | 366 |
17 | JKLGYJ/Q-150/25 | 26/2.70+7/2.10 | 15.50 | 0.00 | 2.50 | 20.50 | 410 | 451 | 729.6 | 1370.6 | 1000 | 0.206 | 51400 | 12 | 366 |
18 | JKLGYJ/Q-150/35 | 30/2.50+7/2.50 | 15.80 | 0.00 | 2.50 | 20.80 | 416 | 457.6 | 804.7 | 1242.7 | 1000 | 0.206 | 61770 | 12 | 366 |
19 | JKLGYJ/Q-185/25 | 24/3.15+7/2.10 | 17.10 | 0.00 | 2.50 | 22.10 | 442 | 486.2 | 818.8 | 1221.3 | 1000 | 0.164 | 56450 | 12 | 423 |
20 | JKLGYJ/Q-185/30 | 26/2.98+7/2.32 | 17.50 | 0.00 | 2.50 | 22.50 | 450 | 495 | 882.8 | 1132.8 | 1000 | 0.164 | 61100 | 12 | 423 |
21 | JKLGYJ/Q-185/45 | 30/2.80+7/2.80 | 18.00 | 0.00 | 2.50 | 23.00 | 460 | 506 | 996.5 | 1003.5 | 1000 | 0.164 | 76180 | 12 | 423 |
22 | JKLGYJ/Q-240/30 | 24/3.60+7/2.40 | 20.00 | 0.00 | 2.50 | 25.00 | 500 | 550 | 1092.6 | 915.2 | 1000 | 0.125 | 71840 | 12 | 503 |
23 | JKLGYJ/Q-240/40 | 26/3.42+7/2.66 | 20.00 | 0.00 | 2.50 | 25.00 | 500 | 550 | 1138.1 | 878.7 | 1000 | 0.125 | 79200 | 12 | 503 |
24 | JKLGYJ/Q-300/40 | 24/3.99+7/2.66 | 23.00 | 0.00 | 2.50 | 28.00 | 560 | 616 | 1327.3 | 753.4 | 1000 | 0.100 | 83000 | 12 | 583 |
JKLGJV结构尺寸表及参数 | |||||||||||||||
1 | JKLGJV-10/2 | 6/1.50+1/1.50 | 4.50 | 0.00 | 1.00 | 6.50 | 26.00 | 33.80 | 67.9 | 14727.5 | 0 | 2.7060 | 4120 | 3.5 | - |
2 | JKLGYJV-16/3 | 6/1.85+1/1.85 | 5.55 | 0.00 | 1.20 | 7.95 | 31.80 | 41.34 | 151.2 | 6613.8 | 0 | 1.7790 | 6130 | 3.5 | 79 |
3 | JKLGYJV-25/4 | 6/2.32+1/2.32 | 6.96 | 0.00 | 1.20 | 9.36 | 37.44 | 48.67 | 145.6 | 6868.1 | 0 | 1.1310 | 9290 | 3.5 | 107 |
4 | JKLGJV-35/6 | 6/2.72+1/2.72 | 8.16 | 0.00 | 1.40 | 10.96 | 43.84 | 56.99 | 214.8 | 4655.5 | 0 | 0.8230 | 12630 | 3.5 | 132 |
5 | JKLGJV-50/8 | 6/3.20+1/3.20 | 9.60 | 0.00 | 1.40 | 12.40 | 49.60 | 64.48 | 283.4 | 3528.6 | 0 | 0.5946 | 16870 | 3.5 | 162 |
6 | JKLGJV-50/30 | 12/2.32+7/2.32 | 11.60 | 0.00 | 1.40 | 14.40 | 57.60 | 74.88 | 475.7 | 2102.2 | 0 | 0.5692 | 42620 | 3.5 | 162 |
7 | JKLGJV-70/10 | 6/3.80+1/3.80 | 11.40 | 0.00 | 1.40 | 14.20 | 56.80 | 73.84 | 380.4 | 2628.8 | 0 | 0.4217 | 23390 | 3.5 | 207 |
8 | JKLGJV-70/40 | 12/2.72+7/2.72 | 13.60 | 0.00 | 1.40 | 16.40 | 65.60 | 85.28 | 629.1 | 1589.6 | 0 | 0.4141 | 58300 | 3.5 | 207 |
9 | JKLGJV-95/15 | 26/2.15+7/1.67 | 13.61 | 0.00 | 1.60 | 16.81 | 67.24 | 87.47 | 502.3 | 1990.8 | 0 | 0.3058 | 35000 | 3.5 | 257 |
10 | JKLGJV-95/20 | 7/4.16+7/1.85 | 13.87 | 0.00 | 1.60 | 17.07 | 68.28 | 88.76 | 540.8 | 1849.1 | 0 | 0.3019 | 37200 | 3.5 | 257 |
11 | JKLGJV-95/55 | 12/3.20+7/3.20 | 16.00 | 0.00 | 1.60 | 19.20 | 76.80 | 99.84 | 866.8 | 1153.7 | 0 | 0.2992 | 78110 | 3.5 | 257 |
12 | JKLGJV-120/20 | 26/2.38+7/1.85 | 15.07 | 0.00 | 1.60 | 18.27 | 73.08 | 95.00 | 618.7 | 1616.3 | 0 | 0.2496 | 41000 | 3.5 | 299 |
13 | JKLGJV-120/25 | 7/4.72+7/2.10 | 15.74 | 0.00 | 1.60 | 18.94 | 75.76 | 98.49 | 692.3 | 1444.5 | 0 | 0.2345 | 47880 | 3.5 | 299 |
14 | JKLGJV-120/70 | 12/3.60+7/3.60 | 18.00 | 0.00 | 1.60 | 21.20 | 84.80 | 110.24 | 1078.2 | 927.5 | 0 | 0.2364 | 98370 | 3.5 | 299 |
16 | JKLGJV-150/20 | 24/2.78+7/1.85 | 16.67 | 0.00 | 1.80 | 20.27 | 81.08 | 105.40 | 727.5 | 1374.6 | 0 | 0.1980 | 46630 | 3.5 | 342 |
17 | JKLGJV-150/25 | 26/2.70+7/2.10 | 17.10 | 0.00 | 1.80 | 20.70 | 82.80 | 107.64 | 776.7 | 1287.5 | 0 | 0.1939 | 54110 | 3.5 | 342 |
18 | JKLGJV-150/35 | 30/2.50+7/2.50 | 17.50 | 0.00 | 1.80 | 21.10 | 84.40 | 109.72 | 856.4 | 1167.7 | 0 | 0.1962 | 65020 | 3.5 | 342 |
19 | JKLGJV-185/10 | 18/3.60+1/3.60 | 18.00 | 0.00 | 2.00 | 22.00 | 88.00 | 114.40 | 797.1 | 1254.5 | 0 | 0.1572 | 40880 | 3.5 | 399 |
20 | JKLGJV-185/25 | 24/3.15+7/2.10 | 18.90 | 0.00 | 2.00 | 22.90 | 91.60 | 119.08 | 929.1 | 1076.3 | 0 | 0.1542 | 59420 | 3.5 | 399 |
21 | JKLGJV-185/30 | 26/2.98+7/2.32 | 18.88 | 0.00 | 2.00 | 22.88 | 91.52 | 118.98 | 955.8 | 1046.2 | 0 | 0.1592 | 64320 | 3.5 | 399 |
22 | JKLGJV-185/45 | 30/2.80+7/2.80 | 19.60 | 0.00 | 2.00 | 23.60 | 94.40 | 122.72 | 1082.6 | 923.7 | 0 | 0.1564 | 80190 | 3.5 | 399 |
23 | JKLGJV-240/30 | 24/3.60+7/2.40 | 21.60 | 0.00 | 2.20 | 26.00 | 156.00 | 187.20 | 1185.3 | 843.7 | 0 | 0.1181 | 75620 | 3.5 | 476 |
24 | JKLGJV-240/40 | 26/3.42+7/2.66 | 21.66 | 0.00 | 2.20 | 26.06 | 156.36 | 187.63 | 1229.1 | 813.6 | 0 | 0.1209 | 83370 | 3.5 | 476 |
25 | JKLGJV-240/55 | 30/3.20+7/3.20 | 22.40 | 0.00 | 2.20 | 26.80 | 192.96 | 192.96 | 1396.1 | 716.3 | 0 | 0.1198 | 102100 | 3.5 | 476 |
26 | JKLGJV-300/40 | 24/3.99+7/2.66 | 23.91 | 0.00 | 2.40 | 28.74 | 206.93 | 206.93 | 1423.0 | 702.7 | 0 | 0.09614 | 92220 | 3.5 | - |
