首页 > 标准讨论 培训学习
[培训资料 ] M22759/192 复合材料电线, 光滑无缝, 镀镍铜,600伏,-65至+260℃,AWG26至10 指标参考
P:2022-03-29 20:38:21
PART NUMBERAWGConductor StrandingApprox LBS/MFTApprox kg/kmmin O.D. (mm)Max O.D. (mm)Cond. MaterialMax. TempVoltage
M22759/192/26-02619/381.432.160.760.86Nickel-Plated Copper260°C600V
M22759/192/26-12619/381.432.160.760.86Nickel-Plated Copper260°C600V
M22759/192/26-22619/381.432.160.760.86Nickel-Plated Copper260°C600V
M22759/192/26-32619/381.432.160.760.86Nickel-Plated Copper260°C600V
M22759/192/26-42619/381.432.160.760.86Nickel-Plated Copper260°C600V
M22759/192/26-52619/381.432.160.760.86Nickel-Plated Copper260°C600V
M22759/192/26-62619/381.432.160.760.86Nickel-Plated Copper260°C600V
M22759/192/26-72619/381.432.160.760.86Nickel-Plated Copper260°C600V
M22759/192/26-82619/381.432.160.760.86Nickel-Plated Copper260°C600V
M22759/192/26-92619/381.432.160.760.86Nickel-Plated Copper260°C600V
M22759/192-24-02419/361.932.980.860.97Nickel-Plated Copper260°C600V
M22759/192-24-12419/361.932.980.860.97Nickel-Plated Copper260°C600V
M22759/192-24-22419/361.932.980.860.97Nickel-Plated Copper260°C600V
M22759/192-24-32419/361.932.980.860.97Nickel-Plated Copper260°C600V
M22759/192-24-42419/361.932.980.860.97Nickel-Plated Copper260°C600V
M22759/192-24-52419/361.932.980.860.97Nickel-Plated Copper260°C600V
M22759/192-24-62419/361.932.980.860.97Nickel-Plated Copper260°C600V
M22759/192-24-72419/361.932.980.860.97Nickel-Plated Copper260°C600V
M22759/192-24-82419/361.932.980.860.97Nickel-Plated Copper260°C600V
M22759/192-24-92419/361.932.980.860.97Nickel-Plated Copper260°C600V
m22759/192-22-02219/342.854.391.011.09Nickel-Plated Copper260°C600V
m22759/192-22-12219/342.854.391.011.09Nickel-Plated Copper260°C600V
m22759/192-22-22219/342.854.391.011.09Nickel-Plated Copper260°C600V
m22759/192-22-32219/342.854.391.011.09Nickel-Plated Copper260°C600V
m22759/192-22-42219/342.854.391.011.09Nickel-Plated Copper260°C600V
m22759/192-22-52219/342.854.391.011.09Nickel-Plated Copper260°C600V
m22759/192-22-62219/342.854.391.011.09Nickel-Plated Copper260°C600V
m22759/192-22-72219/342.854.391.011.09Nickel-Plated Copper260°C600V
m22759/192-22-82219/342.854.391.011.09Nickel-Plated Copper260°C600V
m22759/192-22-92219/342.854.391.011.09Nickel-Plated Copper260°C600V
m22759/192-20-02019/324.386.621.211.29Nickel-Plated Copper260°C600V
m22759/192-20-12019/324.386.621.211.29Nickel-Plated Copper260°C600V
m22759/192-20-22019/324.386.621.211.29Nickel-Plated Copper260°C600V
m22759/192-20-32019/324.386.621.211.29Nickel-Plated Copper260°C600V
m22759/192-20-42019/324.386.621.211.29Nickel-Plated Copper260°C600V
m22759/192-20-52019/324.386.621.211.29Nickel-Plated Copper260°C600V
m22759/192-20-62019/324.386.621.211.29Nickel-Plated Copper260°C600V
m22759/192-20-72019/324.386.621.211.29Nickel-Plated Copper260°C600V
m22759/192-20-82019/324.386.621.211.29Nickel-Plated Copper260°C600V
m22759/192-20-92019/324.386.621.211.29Nickel-Plated Copper260°C600V
M22759/192-18-01819/306.69.91.421.52Nickel-Plated Copper260°C600V
M22759/192-18-11819/306.69.91.421.52Nickel-Plated Copper260°C600V
M22759/192-18-21819/306.69.91.421.52Nickel-Plated Copper260°C600V
M22759/192-18-31819/306.69.91.421.52Nickel-Plated Copper260°C600V
M22759/192-18-41819/306.69.91.421.52Nickel-Plated Copper260°C600V
M22759/192-18-51819/306.69.91.421.52Nickel-Plated Copper260°C600V
M22759/192-18-61819/306.69.91.421.52Nickel-Plated Copper260°C600V
M22759/192-18-71819/306.69.91.421.52Nickel-Plated Copper260°C600V
M22759/192-18-81819/306.69.91.421.52Nickel-Plated Copper260°C600V
M22759/192-18-91819/306.69.91.421.52Nickel-Plated Copper260°C600V
M22759/192-16-01619/298.312.431.61.7Nickel-Plated Copper260°C600V
M22759/192-16-11619/298.312.431.61.7Nickel-Plated Copper260°C600V
M22759/192-16-21619/298.312.431.61.7Nickel-Plated Copper260°C600V
M22759/192-16-31619/298.312.431.61.7Nickel-Plated Copper260°C600V
M22759/192-16-41619/298.312.431.61.7Nickel-Plated Copper260°C600V
M22759/192-16-51619/298.312.431.61.7Nickel-Plated Copper260°C600V
M22759/192-16-61619/298.312.431.61.7Nickel-Plated Copper260°C600V
M22759/192-16-71619/298.312.431.61.7Nickel-Plated Copper260°C600V
M22759/192-16-81619/298.312.431.61.7Nickel-Plated Copper260°C600V
M22759/192-16-91619/298.312.431.61.7Nickel-Plated Copper260°C600V
M22759/192-14-01419/2712.619.051.932.03Nickel-Plated Copper260°C600V
M22759/192-14-11419/2712.619.051.932.03Nickel-Plated Copper260°C600V
M22759/192-14-21419/2712.619.051.932.03Nickel-Plated Copper260°C600V
M22759/192-14-31419/2712.619.051.932.03Nickel-Plated Copper260°C600V
M22759/192-14-41419/2712.619.051.932.03Nickel-Plated Copper260°C600V
M22759/192-14-51419/2712.619.051.932.03Nickel-Plated Copper260°C600V
M22759/192-14-61419/2712.619.051.932.03Nickel-Plated Copper260°C600V
M22759/192-14-71419/2712.619.051.932.03Nickel-Plated Copper260°C600V
M22759/192-14-81419/2712.619.051.932.03Nickel-Plated Copper260°C600V
M22759/192-14-91419/2712.619.051.932.03Nickel-Plated Copper260°C600V
M22759/192-12-01237/2819.629.322.432.54Nickel-Plated Copper260°C600V
M22759/192-12-11237/2819.629.322.432.54Nickel-Plated Copper260°C600V
M22759/192-12-21237/2819.629.322.432.54Nickel-Plated Copper260°C600V
M22759/192-12-31237/2819.629.322.432.54Nickel-Plated Copper260°C600V
M22759/192-12-41237/2819.629.322.432.54Nickel-Plated Copper260°C600V
M22759/192-12-51237/2819.629.322.432.54Nickel-Plated Copper260°C600V
M22759/192-12-61237/2819.629.322.432.54Nickel-Plated Copper260°C600V
M22759/192-12-71237/2819.629.322.432.54Nickel-Plated Copper260°C600V
M22759/192-12-81237/2819.629.322.432.54Nickel-Plated Copper260°C600V
M22759/192-12-91237/2819.629.322.432.54Nickel-Plated Copper260°C600V
m22759/192-10-01037/2630.629.323.023.12Nickel-Plated Copper260°C600V
m22759/192-10-11037/2630.645.843.023.12Nickel-Plated Copper260°C600V
m22759/192-10-21037/2630.645.843.023.12Nickel-Plated Copper260°C600V
m22759/192-10-31037/2630.645.843.023.12Nickel-Plated Copper260°C600V
m22759/192-10-41037/2630.645.843.023.12Nickel-Plated Copper260°C600V
m22759/192-10-51037/2630.645.843.023.12Nickel-Plated Copper260°C600V
m22759/192-10-61037/2630.645.843.023.12Nickel-Plated Copper260°C600V
m22759/192-10-71037/2630.645.843.023.12Nickel-Plated Copper260°C600V
m22759/192-10-81037/2630.645.843.023.12Nickel-Plated Copper260°C600V
m22759/192-10-91037/2630.645.843.023.12Nickel-Plated Copper260°C600V
The asterisks in the above table shall be replaced by color code designators in accordance with MIL-STD-681.
0 - Black, 1 - Brown, 2 - Red, 3 - Orange, 4 - Yellow, 5 - Green, 6 - Blue, 7 - Violet, 8 - Gray, 9 - White
Example: Size 20, white - M22759/192-20-9; white with orange stripe -M22759/192-20-93.
上海富熬电子科技有限公司
分销航空、航天相关特种产品品牌如下:
1、 特殊超细金属丝及超薄带:LFA、CFW、AMETEK、ARNOLD、PCC Rollmet等
2、连接器合作品牌:SOURIAUAERO- ELECTRIC AirBorn、 AMP、 Amphenol、 Cinch、 TE、 ITT、 Radiall、 Rockwell、 Tri-Star、Positronic、Glenair、 Deutsch、THALES等;
3、线缆合作品牌:Nexans、 Carlisle、Harbour、 Nexans、 Micro-Coax、  Draka、  Gore、 Raychem、Thermax;
4、集成电路合作品牌:AD、IDT、NS、SATCON、TI、VICOR、INTERSIL、MICROSEMI、LATTICE;
5、开关/继电器/传感器合作品牌: EATON、HONEYWELL、LEACH、ENDEVCO、DEUTSH、ECE、GRAYHILL、EMRISE,SAFRAN;
上海富熬电子科技有限公司
电话:86-21-5718-0233
传真:86-21-5718-0235
邮箱:sales@sh-fuao.com
网址:www.sh-fuao.com
IT - information theory信息论 点赞(0) 投诉
